URO t-stat leaking
So I have had nothing but problems since the URO "upgrade".
First it was the bad seal on the cap. Bad machining and finish quality. Now there is seepage around the base plate at the connection to the block, and last but not least seepage around the connection at the thermostat.
Could it be the weather? It is now at 15 to 20deg with -0 wind chill. Would the plastic have been better thermolly with this cold?
For now, because of the cold we'll just put up with the smell and keep the res topped up. When does spring get here?
its too cold to mess with the plumbing!
1999 xk8 coupe.
![Icon Errrr](https://www.jaguarforums.com/forum/images/smilies/icon_errrr.gif)
1999 xk8 coupe.
Make certain the T-Stat base plate is torqued down tight. The two back bolts are very difficult to reach and sometimes are not properly tightened.
Read this forum thread: https://www.jaguarforums.com/forum/s...ht=bent+wrench
I can only think the back ones are tight because the front ones were torqued correctly and it is at the front that the seepage is occurring. With that said it could be the rear are over torqued. But either way its not bad enough right now to mess with. Besides its still to cold to mess with. But thanks for your input. We'll be keeping an eye on it. Lets just say that since the install in September until now it has not given me a low coolant warning. I could just smell I had a leak.
Happy Holidays!
Happy Holidays!
