URO Upper Shock Mounts
![](https://www.jaguarforums.com/forum/images/kirsch/buttons/collapse_tcat.gif)
Top Answer
06-30-2024, 08:45 AM
OK, I talked to Tech Support at URO.
I understand they are trying to improve, and the object was to find mounts that would last for a resonantly period of time. Remember, it's still a wear item that will need replacement from time to time.
Don't know how far it will go but I did try to lead them in the right direction. My bad if they take the lead on this, leaving all the molds, equipment and stock setting on the shelf for those of us that have been in the process of keeping the XK8's with decent mounts.
I guess there is still a place for us that rebuild the cores and correct all the problems with the sharp edges that all of the ones I get in have.
I have not talked to Steve yet but feel sure he would or has given them a bit of leadership.
Now, if they will listen, maybe some other things will improve.
I could be wrong in helping but this was an adventure in us trying to help. Pretty sure we did that.
The following 2 users liked this post by rothwell:
Orthodixie (05-03-2020),
srpope80 (05-07-2020)
The following 3 users liked this post by giandanielxk8:
I did some research after a facebook post regarding the URO shock mounts because the material looked an unusual yellow. It seems URO upgraded their material to what they call “a high elastomere rubber”. If anyone has the latest URO mounts, installed please keep us posted on how they hold up.
MaxTorq (04-26-2023)
I have been working on my front suspension a little at a time as time allows. For the live of me I couldn't get the spring compressed enough to get it back together. I tried several technics to no avail. My local tire stores are too afraid of their lawyers to do customer struts carried in. So screw them, I just bought a stand up spring compressor that should do the job and I'll be able to do some for others.
Those URO top mounts will be on soon. I'll report back. TM
The following 5 users liked this post by STLTHMSTA:
EnjoyEverySandwich (05-08-2020),
giandanielxk8 (05-07-2020),
Johnken (05-08-2020),
MaxTorq (04-26-2023),
ozbot (05-07-2020)
WJ and others,
I continue to hear always buy Welch but I've always wondered what is wrong with the stock ones that came in my XKR? Mine stock ones are still good and I can't find anything wrong with them and they have almost 110,000 miles on them......What am I missing here? Are mine different than others because I have the "R" Performance Package? What am I suppose to feel or see that tells me that I need to replace or buy new ones?
I'm confused!
Billy Clyde in Houston
I'm confused!
WJ and others,
I'm confused!
I'm confused!
That is the stock foam mounts. If you notice, the inner bush has turned a reddish color (it was originally cream colored) and the shock is beginning to move askew. I think they have about a year before they go kaput. If you can snap a picture of the shock mount from the wheel well, we can see if the outer bush has started compressing, like in David's example. Is that dust from a dirty engine bay or is it the shock mount producing the dust?
That is good old Texas dust.....I had to remove the Cover Caps in order to shoot the Photo....I'll look under there soon and send you another Photo from underneath the Monster! Bless it's little Heart!! But the point of all this was "What's wrong with Stock Jaguar Parts"? These Mounts have 110,000 miles on them! Answer that all you Welch Guys....
Billy Clyde
Billy Clyde
Billy Clyde
Billy Clyde
However, I suspect that the OE part may last longer than the aftermarket replacements, regardless of who makes them. The problem with the OE part is the price, at $253 each, $506 for the pair is a hefty chunge of money vs what Welsh ($149.95 for the pair), Rockauto (URO $60.79 each/ $121.58 for the pair), and others ask for the aftermarket parts.
The following 2 users liked this post by giandanielxk8:
Gas turbine (07-26-2022),
There is nothing wrong with the OEM part. It is just crazy expensive compared to aftermarket, about 3 times the price last I checked, and not known to last any longer though at this point we are lacking data on how long replacement OEM parts will last. It would be a welcome addition to the analysis if somebody wanted to spend the big bucks on OEM mounts and keep us informed on longevity. Won't be me though as I am too cost sensitive.
From the looks of the pic it is unlikely that those mounts in Billy's car are original when car has 110K on it.
Rothwell,
After my 3rd XKR was Totaled, by the Lady turning left across 3 Lanes of Traffic, I had to quickly find another. This was several years ago and this 2005 XKR Coupe was available in Dallas with around 45,000 miles on it. Since it was the only Black/Ivory one with the "R" Package available out there and I needed a Car, I quickly. bought it. As I found out shortly afterward, the Oil had not been changed in around 40,000 miles and I had to completely rebuild the Engine. My point is, I feel that if you haven't changed the Oil in 40,000 mile, why would you change the Shock Mounts. Sorry but I don't think they have been changed out! Ever!!
Billy Clyde
Billy Clyde
In my case the first time I replaced mine there was under 45K on the car but it was 9 years old by then. That experience makes me skeptical that any mount of this type could go 15 years and 100K+ miles and not have even a bit of crumble in the pic.
Billy,
My mounts at 110K looked okay, not flaking and centered.
At 125K they started to show signs of disintegration and a slight off center lean.
At 130K I hit a huge hole pulling into a parking lot and when I got home i noticed the car was leaning, the left front was lower and the shock was off center.
These were the original mounts on my car.
I hope yours last forever.
wj
Rothwell I checked with my car's previous owner and the mounts had never been changed so I guess the oems do last longer but as you said...x3 the cost.
wj
