Using Waterless Coolant in XK8
#41
If you interpreted my post as a slam against Evans coolant, then you read it wrong. I was simply reporting what happened to one persons car. I was not in the drivers seat, he may have ignored the temperature gauge. My point would be that just preventing a boil over is not necessarily the desired end result.
#42
Ok I understand what your saying Mike.
But that doesn't rule out that water reaches that 15 psi faster at lower temperature because of its lower boiling point.
It's my experience that when an engine has been boiling in most cases there is damage to the engine (cylinder head gasket) which could have been avoided with a coolant with a boiling point that's higher ?
Point being, compared to waterless coolant the margin from normal operating temperature until boiling point and high pressure is a lot smaller with normal coolants.
P.S. Lanny I don't see your post as a slam against evans I wouldn't mind if it was either
#43
Received 2,263 Likes
Without knowing the expansion coefficient of the waterless coolant, the above may or may not be true. I see nothing on their website that discusses this.
#45
I had a shop in Seattle called Community automotive service replace my coolant with the waterless coolant. They seemed to be the only one that knew about it. on my Jag XJ-S Also on my Dodge Viper, Waterless coolant helped in running engines a little cooler. I do recommend waterless coolant for the life of the engine. Good luck mate.
#46
#47
#48
#49
#50
Johnken
09-15-2015 05:46 PM
