Valance/Undertray Attachment
Old 12-11-2011, 02:13 PM
SeismicGuy's Avatar
The ones that were on the car (looks like there are about 7 or 8 attachments total) are clearly a slightly larger size u-nut. The only way I could have used the one you referred to was to grind away some of the plastic or elongate the hole. The alternative one that the parts guy had was about 1/8" longer in terms of where the hole lined up which made it a perfect alignment.
Doug
Old 12-12-2011, 09:05 AM
XKRacer's Avatar
I took a pic quickly showing the type I use, these are the same as fitted at factory as supplied by Jaguar using the part number I gave you, again I am unsure why they would be different?
Here's a pic of 2, each showing a side against a rule so you can get an idea of size.
Old 12-12-2011, 12:16 PM
SeismicGuy's Avatar
The ones that were in place on the car looked just like yours in basic appearance. The one I bought based on the part number you supplied also looked exactly the same in terms of type but a hair smaller than the ones on the car. I should have removed one of the nuts that were on the car and held it next to the one I bought to see for sure but to my eye (also the parts guy) we both agreed that the ones on the car looked a bit larger than XR87652. Then again maybe the hole in the bumper was in the wrong place which might explain why this was the only attachment (out of the 7 or 8 total) that was missing.
Doug
Old 06-11-2014, 03:24 PM
Jim D's Avatar
Originally Posted by XKRacer
Afraid not Doug a very different undertray on the 05MY and are held on by the clips...eeerrr Doug has shown (OK that seemed confusing, is there a group name for a collections of Dougs?)
Would 'Whole' be an appropriate noun of collection for a bunch of Dougs?
Old 06-11-2014, 10:09 PM
Jandreu's Avatar
Any NAPA auto parts store also carries these.
SeimicGuy, mine if I send you a parts order now that you have an in with the warehouse and all.
Old 10-29-2016, 03:17 PM
Pikachu's Avatar
I also noted some screws went missing on my 2002 X-type.
After reading the above, I went to our local shop - Autozone, in Houston, and the sales was very helpful and showed me the GM BODY GRILL/BUMPER RETAINERS (461030A, bar code 76369 46103). It is plastic, $3.50 with tax for 2. Just push it in, it will open and fits well. It supposed to be retrievable.
Hope the info will help others in the future.
Old 10-29-2016, 07:37 PM
RJ237's Avatar
Received 2,799 Likes on 2,236 Posts
I used 6mm machine screws and nylon lock nuts. I don't trust plastic fasteners.
mikiep
12-20-2019 07:37 PM
Poet
06-07-2019 07:54 PM
o1xjr
10-01-2015 09:46 AM
JagBrian
10-01-2015 12:52 AM
ChrisJay
09-27-2015 09:08 AM
Quick Reply: Valance/Undertray Attachment
