valve clatter on startup
+1 on the oil filter. I use the OEM filter from the dealer on my 01 XK8 just for that reason. The small cost difference is well worth it to me for less engine stress.
But keep an eye on it and make sure it not worn valve train issues or rattling primary chains, especially if a filter and new oil doesn't quiet it.
I think it's probably the VVT units on the front of each intake cam. Try this:
After the car has set for a while, start the engine with the bonnet raised, WITHOUT using the throttle. Listen for the "valve noise" and when it's present, goose the throttle once quickly, to about 50% pedal travel.
Does the noise shut up?? If it does, the VVT's are the culprit. They get worn and oil drains out of the units, blipping the throttle activates them and they charge with oil. That quiets them down. Tensioners won't help that any, only VVT replacement will do.
Cheers,
Cheers,
I think the OE oil filter has a non return valve in it which stops the oil draining back out of parts of the top end.
I have had top end enging start up noise on my 4.2 for the last year which has just gone with an oil/filter change last week.
Chuck Schexnayder
33
10-24-2015 10:20 PM
