Valve cover gasket
Valve cover gasket
I'm getting ready to do my secondary tensioners and just want to confirm that the Felpro gasket set, VS50724R, will fit my 2001 XKR. I know this fits the Lincoln LS and all the websites say that this gasket set does not fit the Jaguar, but I see it has been used by others changing out the tensioners. I just want to be reassured it will fit before I place an order. Thanks
The Felpro should fit the AJ27 4.0 Liter Jag Engines.
I am just now replacing my leaky valve cover gaskets for the second time. I can't remember who made the first set, but they were pretty poor, and not nearly as good as the Fel-pro set. The first set did not have the bolt washers either. Now all I need is to find the torque setting again. Yes I will also conferm that, the part number you have is correct. Good luck.
xjrjag
09-27-2015 01:53 AM
1964Daimler
09-09-2015 11:20 AM
