Valve cover gasket set
Old 02-09-2019 | 07:04 PM
MDsjag's Avatar
Default Valve cover gasket set
Is it possible to buy a complete valve cover gasket set? I’m having trouble locating this for 97 4.0 XK8.
Old 02-09-2019 | 08:13 PM
RJ237's Avatar
This is the set I bought for my 97 several years ago. I think it's actually cheaper now.:
Valve Cover Gasket Kit by Motorcars Ltd part NCA2515/2516AE - MotorcarsLtd.com
MDsjag (02-10-2019)
Old 02-09-2019 | 08:16 PM
RJ237's Avatar
oops- you also need a set of isolators, that's why it's cheaper.
Valve Cover Isolator - MotorcarsLtd.com
MDsjag (02-10-2019)
Old 02-09-2019 | 09:44 PM
DavidYau's Avatar
Default 1999 XK8 4.0L Convertible in Bahrain
I presume you mean the camshaft cover gasket. Try https://www.terrysjag.com/
Great service with on line chat with someone in case you have a problem. Just be careful with your 1997 Gen1 model, as my 1999 XK8 had the AJ26 engine switched out for a AJ27 engine. The two engines have a different gasket sets. as can be seen from Terry's Jag website.
MDsjag (02-10-2019)
Old 02-09-2019 | 10:08 PM
zray's Avatar
There is also some information on the sticky list, the OEM parts interchange topic, that might be useful.
Z
MDsjag (02-10-2019)
Old 02-10-2019 | 10:24 AM
MDsjag's Avatar
Old 02-10-2019 | 10:25 AM
MDsjag's Avatar
Thanks for the help! Greatly appreciated!!
wrd0225
05-05-2024 02:30 PM
David Bedoya
01-15-2017 05:12 PM
Lisa Lou
General Tech Help
01-23-2016 04:24 PM
Roger77
01-17-2013 10:49 AM
Quick Reply: Valve cover gasket set
