View your build sheet/ options in your XK8
Hi folks,
Just an FYI..I just found a way we can look at our cars build sheet by going to this ford website..this is probably been posted here before but just in case those that don't know, here it is... enjoy!
FordEtis home page
FordEtis home page
The following 8 users liked this post by zidjan:
bazjag (03-31-2016),
blindside (04-02-2016),
cyber3d (03-31-2016),
JimmyL (04-01-2016),
rperformance (03-31-2016),
and 3 others liked this post.
Hi folks,
FordEtis home page
FordEtis home page
Steve
It didn't show mine either, but I wasn't surprised. My Jaguar Heritage certificate says that the build date for my car is "Not Recorded". How can I expect Ford to know these things if Jaguar doesn't?
But thanks anyway to zidjan for making this site known. I'm sure it can help owners of newer Jags than mine.
Vince
Vince
Received 2,397 Likes
Used it a few days ago to get basic info on 434Mhz's 96. I've not had a fail yet with either US or EU samples. Must just be lucky, I guess, although I've seen more than one instance where the reg. documents are wrong. Mine records a 'D' that is really a zero..
There's not much info on the early VINs, but becomes more informative from 1999 onwards.
M
Code:
Build Date: 08.02.2000 Vehicle Line: Jaguar X100 Body Style: Cabriolet Version: Series 20 Engine: JAG-4.0L DOHC EFI NA V8 GAS Transmission: 5 Speed Auto Trans ZF 5HP24 Drive: LHD RWD Axle Ratio: 3.06 Final Drive Ratio Emission: LEV Requirements Air Conditioning: Automatic Air Conditioning Territory: (+)"USA" Minor Features Marketing Level 1 Less Warning Display Less Heated Windscreen With Console Cup Holder Less IP Facia Monotone Colors With Electrochromic R/View Mirror Cabriolet Dual Power/Heated/Memory Mirrors 1 Flat / 1 1400MM Convex - NAS With LH Electric Lumbar Support With RH Electric Lumbar Support With Drivers Heated Seat With Heated Passenger Seat With Driver 6 Way Pwr.Seat Adjuster With Pass 4 Way Power Seat Adjuster With Programmable Driver Seat 315 MHZ Door Lock Frequency With Automatic Windscreen Wiper With Headlamp Washer Less Isofix Hard Point Attach Limited Service Mini Spare Tyre With Performance Suspension Less Handling Package 3.06 Final Drive Ratio JAG-4.0L DOHC EFI NA V8 GAS With Catalyst With Anti-Spin Traction System With Onboard Vapour Recovery System With 95 Octane Level Petrol Fuel Tank Filler Neck - Unleaded With Power Tilt Tele Memory Column With Speed Control Less Navigation System Less Reverse Proximity Sensor Less Engine Immobiliser With Safeguard Anti-Theft Sys(Pats) With CD Player Autochanger Premium (+) Sound With CD With 8 Speakers Less Telephone Preparation Pack With Garage Door Opener With High Mounted Stop Lamp With Automatic Headlamp On/Off 5 Speed Auto Trans ZF 5HP24 Jaguar X100 Series 20
The FordEtis website data appears to be less detailed than Jaguar's Direct Dealer Warranty System data.
Using the VIN for my last 2005 XK8 4.2 S Coupe ( VIN SAJAC41P362A47779 ) as a test, FordEtis returns more generic results for the options level details.
Here's the Direct Dealer Warranty System data:
(click on the images to enlarge them)
Anyone can check this equivalent FordEtis output using my VIN.
FordEtis is a useful tool but I'd go with the Direct Dealer Warranty System printout where available.
