VIN Discrepancy
Old 10-30-2019, 10:59 AM
Tijoe's Avatar
Originally Posted by Diddion
Ok, you asked for help. You got it....
So what does our friend Google say? CS is clearly an acronym. I believe it stands for Constant Speeding, because it is unlikely to be Catastrophically Slow.
For another 300 or so alternatives check here. Acronyms of CS
I hope my undoubted but questionable erudition helps.
On a more serious note, I wonder whether it could indeed have anything to do with proposed export country, as Tijoe suggests. But if that were the case then one would expect many exported Jags to share the same CS letters. This really is an intriguing issue, because if it does mean an unassigned country for export, then surely all left hand drive cars should have the same designation.
Since we started going down this path....
I saw one reference for a batch label printer where "CS" stands for "completed series" Its instructions stated that when you are printing out a series of documents where each document has an incremetal number identifying each document. Perhaps, an employee at jaguar who prints out door labels has a similar printer, but he messed up and the "CS" was added to this VIN on the label rather than being used as an end of record indicator.
Old 11-01-2022, 02:55 AM
johnnyander39's Avatar
Which model of Batch Printer did you saw it? I think there are also mentions like this on the Munbyn label printer, right na?
Old 11-01-2022, 02:56 AM
right na?
Old 11-04-2022, 02:04 AM
Pistnbroke's Avatar
I think its quite simple ..the machine that prints the vins has limited length for the string of letters so the printer put CS at the end to indicate the end of that model year . Note the date August ...the factory closes in august for "Coventry holiday week" during which time management gets ready for the next model year production.
calion
09-25-2012 07:48 PM
Stephen B
05-08-2011 02:57 AM
EcbJag
03-17-2011 07:58 PM
RSVG
07-27-2010 05:20 AM
spielnicht
07-14-2008 07:50 PM
Quick Reply: VIN Discrepancy
