Is VIN on engine block?
Good afternoon,
I am looking to purchase a used engine for my 2001 XKR and would like to know if I can verify a used engine's milage and origin with a CARFAX report.
Mike
- Where is the engine ID stamped?
- Is the VIN stamped on the Jaguar's original engine?
Mike
There is no VIN on the engine and other than the original assembly build sheet no relationship between the VIN and engine serial. A dealer can print the vehicle build sheet from the VIN . . . but you have to start with the VIN.
The engine has a serial number that is coded with the date of manufacture at the engine plant . . . not the vehicle assembly. The format is yymmddhhmm.
then there is no way to verify actual miles on a used engine...
So if I understand correctly, there is no way to verify that a particular engine came out of a low milage car. But you could verifiy by dates and options that an engine did NOT come out of a particular car, especially if the engine seller presented a VIN with a build date preceeding the engine build date.
Thank you,
Mike
Thank you,
Mike
I don't think the system is setup to work in reverse to identify the VIN of a car from the engine number.
just pulled the RH valve cover...
under the RH valve cover i found both cams broke in two and the bearing caps loose. some stripped out of the block. not sure if I can re-tap for the next size larger diameter bolts and install used cams. I met the hack in Miami who repaired the engine after a timing chain failure, so I guess I better check the LH camshafts also.
not sure where I'm going to find used camshafts, even if I can fix the stripped out bearing cap holes in the head.
I guess this explains why I always had low oil pressure at idle after it warmed up.
Dicque
09-19-2015 12:53 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
