Visor Mirror Repair (Video) FAQ
Old 09-08-2010, 11:26 AM
rweber's Avatar
One thing to remember if you haven't done this yet is to absolutly remove the visor from the car. In the video, the two little clips are pulled out of the visor from under the mirrow assembly. Removing the mirror while the visor is still attached to the car allows the clips to fall out onto the floor. The clips are black and my carpet is black- the clips disappeared completely. I searched with a flashlight, until I convenced myself that they weren't there to start with, I put it back together and said Il'l try it again later. So while driving to the movies my wife, not wearing shoes, found the clips.
Old 09-08-2010, 01:44 PM
Reverend Sam's Avatar
Received 1,261 Likes on 565 Posts
LOL! Good point! It only takes a few seconds to remove the mirror from the car. It's just two phillips head screws.
Also, the correct glue is important. That five minute epoxy stuff that I used was ideal because it remains slightly flexible after it hardens. A lot of other glues are going to get brittle, and since the glue is holding a spring, the glue will crack and the spring will fall back out.
Old 11-04-2010, 02:53 PM
I just discovered another video on youtube that's sorta like a follow-up to my video. Someone had a broken hinge pin on their mirror cover and they repaired it with a nail. I added their video to the my original post in this thread so that both videos are right there together.
Old 11-09-2010, 11:24 PM
Wolfy's Avatar
Default I lost the metal clips! (Re: Visor Mirror Repair)
I lost the metal clips that hold the visor flaps in place. Where can I buy them??? I am in Los Angeles.
HELP!!
Old 11-10-2010, 12:29 AM
2000CAXK8's Avatar
I just joined today and I see that, thanks Sam. P.s. that little nail is still working great
Old 11-10-2010, 04:26 AM
guzzi svt's Avatar
I am 6'2" and after almost running a freeway exit stop light I decide to just reove my driver side visor. This adds quite a bit of added vision to things above the car. I also removed the center rear view mirror for the same reason. I ride motorcycles a lot so I'm use to just using the wing mirrors.
But thanks again Sam for a great video.
Old 05-16-2011, 06:48 AM
deadboy1977's Avatar
I have not done this yet but need to....one question, does the short end of the clip go towards the outside of the visor??? Maybe it only goes in one way??
  #28
Old 05-16-2011, 08:34 AM
One side has a small barb in it. The barb is to hold it in the slot and the barb is supposed to point toward the flat side of the slot that doesn't move, not the hinge on the flap.
Old 05-18-2011, 08:56 PM
ok barbed side AWAY from hinge
U goes in slot with the 2 prongs UP right?
  #30
Old 05-18-2011, 09:47 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
This might help http://jagrepair.com/MirrorRepairSunvisor1999xk8.htm
deadboy1977 (05-19-2011)
  #31
Old 05-19-2011, 10:30 AM
Ed M's Avatar
Thumbs up
Whoa, it does! Thanks for the tip. But now there's a big hole where the visor screwed in...
I love this forum.
  #32
Old 06-25-2011, 04:09 PM
jjrglobal's Avatar
Default Any idea what number that fuse is
that goes to the visor light
  #33
Old 06-25-2011, 04:33 PM
Gus's Avatar
Gus
Gus is offline
Not knowing what year car or the side I would check the fusebox on the left or right side door.
jjrglobal (06-25-2011)
  #34
Old 06-25-2011, 05:46 PM
jjrglobal's Avatar
Default It says in the owners manual
stoneworker lights??? Any idea what a stoneworker light is?? Also, do you know if the visor lights will come on without the key in the ignition? I'm trying to hard wire my radar detector and since I destroyed the clips in my visor mirror and had it unplugged I figured I would put that circuit to use. Thanks Gus for all your help
  #35
Old 06-25-2011, 05:49 PM
jjrglobal's Avatar
Default OHH Duh
Its a 2002 XKR Coupe, I cant find it anywhere in the owners manual
  #36
Old 06-26-2011, 05:47 PM
reko19's Avatar
Sam,
Great instructions as always. Just took care of mine. Anyone knows what powers up the lights? I see two wires going into a visor but they are not connected to anything inside the car, I was expecting a connector when I was removing a visor. Both of my lights are dead.
  #37
Old 10-16-2011, 01:10 PM
drk1074's Avatar
Thanks again Sam, for the video. I didn't have any epoxy on hand, so I used some of my wife's clear nail hardener for adhesive. The stuff is as thick as molasses, so we will see how it holds up.
  #38
Old 10-16-2011, 01:22 PM
Originally Posted by reko19
Sam,
Sorry Reko, I just noticed your post. I know this is four months late, but if you'll look at the clip that holds the inner part of the visor in place you'll see two little springs. Those springs are the metal contacts that provide power to the lights. In other words, the lights will only work if the visor is snapped in place. If you have it rotated to the side to block the sun from the side of the car it won't light up.
That might work, but I bet it will end up being too brittle and it won't bond to the plastic. You never know, though. Let us know if it holds up.
  #39
Old 04-19-2012, 04:47 AM
barkergl's Avatar
Default XK8 Drooping Sun Visor Mirror
My XK8 had exactly the same problem with the passenger sun visor mirror not staying up. After taking courage from seeing the Reverend Sam video I opened up my visor mirror and found clips lying inside as per the video. So was quickly able to make a fix - to my wife's delight. Thanks.
  #40
Old 07-25-2013, 03:15 PM
Joanie's Avatar
I don't have a problem with the mirror, that's just fine. My problem is the entire visor came off on the part that is screwed into the car, I detached the visor entirely now. I see a large center hole and two small holes on each side of it where the screws should screw in. Will this be a problem to tightly screw it back up in the same holes again and will it hold tightly? Before it came off entirely it was flopping down a bit, didn't snap up tightly as the other side.
Quick Reply: Visor Mirror Repair (Video) FAQ
