Voltage Sensing Problem
Old 06-17-2011 | 01:29 PM
jazzwineman's Avatar
Default Voltage Sensing Problem
Friend (blackcat2000) has 2000 XKR (75K) He had a bad alternator, no ifs and or buts. The gauge showed clear dropping in readings from the normal 13- downward to below 11. Replaced alternator. Readings show 14 at battery and alternator and yet there is a message on the message center that indicates "battery not charging" and a battery light is lit on instrument pane. The gauge shows a straight 13 and the battery is being charged and the battery is brand new with in the last 3-4 months. No heck engine light. Any ideas. Apparently the voltage is consistent across the engine- so why the message and light. What is in between that could cause an error read.
Tom in Dallas
Old 06-17-2011 | 04:56 PM
Dennis07's Avatar
He replaced the alternator, not the gauge, right?
Is there any problem other than what seems to be an inaccurate reading on the gauge (throwing codes, something like that) ?
Old 06-17-2011 | 08:45 PM
WhiteXKR's Avatar
Have the battery load tested at an auto parts chain store.
If the battery is OK, then have them check the OBDII codes for free, and also read what the OBDII code reader reports for voltage with and without the engine running.
Old 06-17-2011 | 09:30 PM
Here are additional facts:
Please see additional facts
Old 06-17-2011 | 10:41 PM
WhiteXKR's Avatar
How long has it been since he changed the alternator? It might take several drive cycles for the fault to clear on its own, if it is not cleared manually with an OBDII scan tool.
OkieTim
09-08-2015 05:48 PM
hafren
09-07-2015 11:30 AM
jaguarbill
09-05-2015 12:43 PM
Sprayall
09-03-2015 08:49 PM
OkieTim
09-02-2015 01:48 PM
Quick Reply: Voltage Sensing Problem
