VVT and cam timing help needed
#61
#62
"In normal operation, the ECM uses the inputs from the crank sensor and the A bank cam sensor for cylinder identification
and ignition/fuel synchronization. If the A bank sensor system fails, the ECM switches to the B bank inputs. If
the crank sensor system fails, the engine will start and run using the inputs from both cam position sensors." (my emphasis)
Mike
bob
#64
