VVT Seals - A Question
I understand it is wise to replace them if they are weeping oil. They are located on the valve/cam covers at the front of the cover.
My question is since they appear to be a flush fitted seal, do you have to pull the covers and install them from the back side? A press fit.
I thought I had read a couple of week ago that a member said you could simply pop them out with a screwdriver without removing the cover. I did some feeble attempts at that and was concerned I was going to damage the existing seal.
Any assistance will be appreciated.
JagXK82001 (05-17-2017)
