Vvt solenoid
Old 07-18-2016, 03:55 PM
Dale Dunn's Avatar
Default Vvt solenoid
Anyone know where I could locate a Vvt solenoid connector? Any help is greatly appreciated
Old 07-18-2016, 07:05 PM
TerryM's Avatar
Default Connector
Crazy, I was just about to post the same question!
I just got off the phone with Terry's Jag Parts and they suggested trying a Ford parts department. She said that Jaguar doesn't offer the parts but she recalled a previous customer who had luck sourcing them from the Lincoln 3.9.
I'll try and check it out tomorrow unless someone has another idea.
RJ237 (07-18-2016)
Old 07-18-2016, 07:32 PM
Dale Dunn's Avatar
Let me know if you find out anything. Thanks
Old 07-19-2016, 04:17 PM
TerryM's Avatar
Default Connectors
Went to the Ford parts dept. today and they were much more helpful than the local Jaguar dealer.
We looked through a catalog of connectors and found one that looked similar and he ordered it for me.
I also ordered one from Rock Auto that was recommended on this forum.
I'll let you know what works and post part #
Old 07-19-2016, 05:41 PM
Dale Dunn's Avatar
Do you have rock auto part #. I saw one on their web page that looked correct but could not tell for sure
Old 07-19-2016, 06:48 PM
TerryM's Avatar
Default Part #
I should get both parts this week and will check fit when they arrive.
The Rock part is AIRTEX / WELLS - 1P1792 (1160) $33.79
I would wait till I can check fit before ordering though.
Old 07-19-2016, 07:12 PM
Dale Dunn's Avatar
OK. I can wait. Just let me know. TIA
Old 07-19-2016, 07:55 PM
Received 8,218 Likes on 4,955 Posts
Y'all do realize that there are 2 different VVT actuators!!!!!!!!!!!!!
One is an actual on/off solenoid (FULL ADVANCE, FULL RETARD) and the other is an actuator that is controlled to vary the intake cam by degrees.
Are you both on the same page???? cause Dale Dunn does NOT specify the Make, Model, Year. (AJ26 or AJ27??)
Just trying to clarify.
bob
Old 07-19-2016, 08:00 PM
Dale Dunn's Avatar
I thought I had posted info but must not have. I just recently acquired car. 99 xk8 with 4.0
Old 07-19-2016, 10:18 PM
dsnyder586's Avatar
PM me if interested in a used one- I have a couple harnesses laying around and will send for cost of shipping. I have both an AJ26 harness and an AJ27.
Old 07-20-2016, 11:30 AM
TerryM's Avatar
Default Vvt
Dsnyder586 thank you very much for your offer but the connector I picked up from Ford fits perfectly.
As Bob points out to clarify I have a 01 AJ27 with the unit coming out through the top of the valve cover.
The Ford part number is - AU2Z-14S411-ADA
Old 07-20-2016, 11:55 AM
dsnyder586's Avatar
Excellent- glad you got it squared away! Thanks for posting the part number for posterity.
Dale Dunn (07-24-2016)
Old 07-24-2016, 08:48 PM
Dale Dunn's Avatar
Got connector yesterday and have letter ready to go out to you. Thanks again ver much
philwarner
47
07-28-2016 03:29 AM
Doug
07-15-2016 03:45 PM
malc4d
07-13-2016 09:20 AM
marmar1305
07-10-2016 10:10 PM
rwilcoxen
06-22-2016 12:35 PM
Quick Reply: Vvt solenoid
