Warning light: Failsafe check rear taillights
Anyone out there seen this message on their XK8 (mine is a 2002) and if so how do you find & fix it? When this comes on the cruise control is in op & the red light on the console goes off. If you shut off the ignition for several seconds the light comes back on, and the cruise MAY or MAY not work foe a while.
kstevusa (09-21-2022)
The OEM brake switch is kinda pricey. I tried the solder of micro switch, but my ability was lacking. Gave up and purchased a less expensive A/M switch from Rockauto, It has functioned well since purchased in February this year. Installed using the "fishing line method" with an assistant.
erniejenson
08-21-2017 11:13 PM
