Warped cylinder heads, up to 20/1000 - try new heads or consider engine dead?
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
So after the overheating incident, turns out my cylinder heads got warped 20/1000", the shop that recommended the $750 tear down assuming this would not be the case STRONGLY recommends a new engine which would be at least $2000 for the engine and $1500 for labor which I can't afford and there are risks associated with that too.
Is there any way to investigate for cracks in the block with the heads off? I reckon a new head with a cracked or warped block would be a big fail. On the up side the valves did not drop.
Also, would XJ8 head(s) such as this work?
Jaguar XJ8 98 03 Vanden Plas Right Passenger Cylinder Head XR83 6C064 AE | eBay
al_roethlisberger
09-11-2015 10:04 PM
KarimPA
09-03-2015 07:32 PM
