Water inside trunk
Hello all,
I have a 2003 XK8 and have the car parked with the rear end high, well it rained and was sunny the next day, so I decided to wash her up, after drying the car off, I lifted the trunk up and there was pooling water inside the trunk, upper portion of trunk where the trunk lid struts are, is this normal?? The carpet portion was dry, but I was somewhat alarmed at how much water was near the trunk lid struts, i checked all rubber and it is soft and undamaged
should I be concerned?
Thanks in advance
Rick
Thanks in advance
Rick
Hello all,
Thanks in advance
Rick
Thanks in advance
Rick
Figured out why this happens. When the vehicle is parked nose down at a steep enough angle, the water pools at the trunk seal in the areas at the rear screen. The water wicks up the seal where it is press fit over the metal seam of the scuttle. Remove, clean and seal it with something appropriate or park in the opposite direction.
