Water pump gasket help
Hi all, I'm stymied. I replaced the water pump on my 2000 XKR and now it leaks at the seal, what am I missing? I have an OEM pump from the dealer - white plastic impeller. The gasket supplied has rubber around the two smaller holes on each side but nothing to seal the large round hole in the center - it's just metal on metal. I don't want to seal it with silicone and I threw away the old pump and gasket before I realized the new one leaked, so I'm not sure how the original sealed the center. I found an o-ring at Rock Auto for a 2000 XKR water pump but I don't see how to use it if that's the solution. I feel really stupid that I can't figure this out on my own but I've had this apart three times now and I'm getting pretty tee'd off as you can imagine.
If you can help, I'd sure appreciate it. Have a happy 4th of July!
Ken
Ken
You really ought to get around to downloading JTIS. You will find pointers to it in various stickies and faqs.
But, seeing as it is a long weekend:
An O-ring and an aluminum-alloy gasket, seal the ports between the pump and the cylinder banks.
The O-ring goes between the block face and the gasket according to the illustration, and fits into a machined recess.
You might consider ordering a new gasket as well in case not using the ring has made it unusable.
Y2K XKR (07-01-2011)
The o-ring goes in the recess. The snout is not involved. Jaguar water pumps don't wear nose rings.
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
chatmanx
09-11-2015 07:17 PM
