Water pump roulette
Received 2,397 Likes
MsMaybe98 (05-19-2022)
OK so I'm changing the pump. I watched a video that made it look straightforward apart from draining the coolant which he let come out of the pump into a bucket.
That doesn't seem t so great to me, I thought there was a tap or something at the bottom of the radiator. He didn't seem to want to touch it which I thought was a little odd.
Any advice please?
Mike
Any advice please?
Mike
I have been using that tap on several Jags over the years with no problem, others have said it broke off. If you do use the tap open it just enough to let the coolant dribble out, or it will be all over the front of the cat and no better than just loosening the pump and letting it drain.
My procedure now is to snake a 1/4" hose down through hose at the bottom of the pressure tank and siphon as much as possible from there first.
FWIW, you can drain quite a bit from the overflow tank. Use a turkey baster and a clean container. Then remove the overflow tank and keep draining from the bottom hose with the same baster (you can lower the hose by hand to remove even more). Should get the level low enough to replace the pump without making a mess. You don't need to get all of it out, and, if new enough, you should be able to reuse it.
You are going to want to put the hood in the vertical/service position for this job.
Best of luck, keep us posted.
Well the job itself is much as described and doing it again I would be much quicker I'm sure.
So far dry as a bone with a test run, then my two five mile trips and the water temperature was the same as usual so that's all good. I just drained the coolant from the pump slowly and collected it. I shall replace all the coolant as I suspect it's geriatric - rather like me.
So far so good and once many thanks to a very helpful forum!
Mike
Mike
You need to press down on the cap while turning it to get it to catch. I think that's the 'O' ring. It's the same on the original reservoir and the OEM I replaced it with.
I normally nip it up then back off a 1/4 turn, as the seal isn't dependent on it being tight. Easy to undo from there if necessary.
JimmyL (05-20-2022)
Received 1,684 Likes
my cap did the same thing. You couldn’t tell it by looking at it, but it was slightly warped. Like yours it held the pressure perfectly but was hard to get started on , and off.
I decided to try a cap from my spare (and new) reservoir. It goes off and on perfectly.
Z
