Water Pump or Thermostat?
Old 11-03-2011, 09:42 AM
thenaz007's Avatar
Always boil the T-stat and make sure it opens before installing it. If you think the chances are so low it will happen to you - it has happened to me 3 times! A lot of bad ones slip through and then you start replacing everything else to avoid taking it to the dealer! Also the Jagbits Aluminum T-stat housing does not have the rib and all "correct" T-stats seem to fit.
Wahooesprit
12-23-2019 02:01 PM
Ozzy_UK
45
02-19-2019 02:05 PM
Ozzy_UK
General Tech Help
01-14-2016 02:52 PM
picard
10-12-2015 11:56 AM
Jaiello21
09-14-2015 09:42 PM
Quick Reply: Water Pump or Thermostat?
