weep from top pipe on thermostat
I am surprised you still have what looks like an original surviving 4.2l plastic thermostat assembly. The plastic on these disintegrates and cracks and will only lead to a series of troubles. It is strongly suggested to replace the whole assembly, which include a new thermostat and temp. sensor and should be under 100 GBP.
RaceDiagnostics (03-22-2015)
Thanks, just bought this one from DMG for £36.
Brand New Thermo Housing in Aluminum for Jaguar XJ8 and Jaguar XK8 Cars | eBay
Looking at the site I googled the jag pt# they were providing, it only showed replacement for up to 02, keep in mind you are 1 year ahead over there so your 02 has the 4.2 where here they are all 4.0, ensure they just didn't check the year compatability, also check the return policy just in case.
I emailed them and got this back.
So I called them, and they confirmed that it would not fit.
I had another look on ebay and found listing s for aluminium housings that say they are for 4.2 engines, here is one.
JAGUAR XJ8 / XK8 ALUMINIUM THERMOSTAT HOUSING TOWER - AJ82217 | eBay
Hi sir yes sir will fit all xj8 and xk8 ma...
Thank you for your due diligence, I think many were hoping you were right but alas, you saved time getting things apart and finding the wrong part was ordered, I hate when that happens. Otherwise Most seem to be happy with the plastic replacements the orig one latest 10-15 years so the new one will be good for some time.
aholbro1
08-05-2021 05:02 AM
