Weird Transmission Fault
It's been getting cold some night here lately. And when starting the car the xk8 I get a transmission fault as soon as the car starts. This is before I put it gear It only happens when the outside temperature is 40F or lower. I let it get to operating Temp and turn the car off and restart it and it is fine. I get an engine light sometimes and the code I pull up is P0763 which is solenoid c. As I said it only happens when the temp is cold and the car has set around 8 hours. One other thing I noticed is it takes longer to crank when cold and I'm thinking it is battery related. Thoughts?
...... This is before I put it gear It only happens when the outside temperature is 40F or lower. I let it get to operating Temp and turn the car off and restart it and it is fine............. One other thing I noticed is it takes longer to crank when cold and I'm thinking it is battery related. Thoughts?
JajJohn (12-13-2012)
If you can get under the car you want to look at the bayonet plug to the transmission (the one connecting to the trans) and see if you have a poor connection in one of the pins. Use a good contact cleaner and a little dielectric grease. Not a common problem with Jag but has been noted with other ZF transmissions.
JajJohn (12-14-2012)
aholbro1
08-05-2021 05:02 AM
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
