Welch shock mounts vs Jaguar OEM
Received 1,702 Likes
Ignoring any cost differences, are these two options now equal in theoretical longevity. Or are the newish, and apparently diminished, Welch mounts still better than Jaguar OEM ?
My mounts, shocks, and associated bushings were replaced by a previous owner @ approximately 114,000 miles. Now another 52,000 additional miles have been racked up. Judging by ride quality, ride height and visual inspection the upper mounts are still in remarkably good condition.
However. I know this state of grace won’t last forever. I’m aware of the ongoing efforts by forum members to manufacture a quality replacement, but for now I’d just like to have opinions on which product is going to last the longest, the Welch, or the OEM.
Z
Z
In my personal experience driving on the surface of the moon, aka, Puertorican roads, the Welsh mounts are lasting about 11 months on average. The OE mount pancaked flat after about 10 years. I never tried aftermarket OEM-style mounts. My experience may be an outlier given the state of the roads in PR. However, recent adopters of the Welsh mounts are seeing their mounts fail just a few months after the warranty expires. Welsh seems content to leave it as-is instead of responding to the issue as their customers shed light on it for them. If they have the arrogance to believe they have the market monopoly on "upgraded mounts" even after they dropped the quality of their products, they are in for a shock once a better product appears. Word is already spreading about how the quality of their product has dropped and how they have treated customers who reach out to them.
cjd777 (04-28-2021)
Below is my reasoning from an earlier discussion on this.
With the OEM part being about 3X the price of Welsh/URO for me that is a deal breaker. I would rather risk replacing them more often than spending that much up front in hopes they last 3X longer than the non-EOM.
I have replaced them 3 times so far over 70K miles and 7 years. Getting pretty good at it now.
Well I have replaced two sets of uro foam and one set of welsh poly so far...
The reason that I will reluctantly continue to use the Welsh is because even though they fail too soon it is the inner bushing that seems to fail which is opposite of the foam mounts where the outers tend to collapse first. So with Welsh I will get shock clunks and will know to replace them well before alignment is affected. The others will just collapse and can ruin your tires before you can likely catch it due to adverse alignment with no noise until the very worst point when the metal starts rubbing together.
I have stated before that I think the sweet spot is a welsh outer bushing with a stock inner bushing.
sklimii (04-29-2021)
zray (04-29-2021)
The following 2 users liked this post by Jon89:
cjd777 (04-29-2021),
giandanielxk8 (04-29-2021)
My original, from the original build, mounts lasted until 135K.
I have installed welsh units and plan on purchasing a set or two of Wayne's when he has them finished. When I install new shocks I'll pull the welsh units and sent them to wayne as their housing are useful.
If it was a choice between welsh and Jag oem I would go with Jag oem. I enjoy working on the car but not continually replacing the same items in short order.
wj
wj
That would be a great solution, if my current Jag mounts can continue to hold up until Wayne’s product is available.
However they are on a daily driver with over 50,000 miles on them. After reading many postings relating the failures of this part, I suspect I’m driving on borrowed time.
Z
Z
Z
Pretty sure that is what happened to me with my last set of Welsh ones. They just can't handle severe impacts and the center bushings fail.
cjd777 (04-29-2021)
How do I find-out about Wayne's product? Appears I am in need of replacing the Welsh mounts....again....
