What code should a leaking intake manifold gasket produce?
I have a check engine light w/intermittent restricted performance (restricted performance seems to happen when the vehicle is slowed down at stop lights not normally when it's up to speed), code p0171. Mechanic diagnosed it as a leaking intake manifold gasket but I'm thinking it might be a miss diagnosis. Wouldn't a leaking intake manifold gasket produce both p0171 + p0174 if not an additional code along with them?
Thanks for the help
Thanks for the help
![Icon Really](https://www.jaguarforums.com/forum/images/smilies/icon_really.gif)
Lean codes left unrepaired will cause the ECU to compensate by enriching the fuel mixture which will eventually lead to catalytic converter overheating and damage/failure. Then there's the extra fuel $$ spent, the washing of oil from the cylinder walls... The larger the air leak, the more fuel added, the quicker the issues arise. Just trying to point out that foot dragging on this repair isn't a good idea.
Just call me little Merry Sunshine. ;-)
clubairth1
29
05-10-2024 12:57 PM
aholbro1
08-05-2021 05:02 AM
rachelstr
09-03-2015 12:59 PM
