The "What did you work on today" thread.
Old 10-06-2017, 05:18 PM
smoggyx100's Avatar
Well its in and pulling like a train. So a 4.0 can be converted to a 4.2
Johnken (11-13-2017)
  #302
Old 10-06-2017, 09:34 PM
chillyphilly's Avatar
Smoggy, do you plan on writing a "how to" for the swap? Curious on what all needed to be replaced to convert to a 4.2.
  #303
Old 10-07-2017, 01:32 AM
Johnken's Avatar
Received 1,810 Likes on 1,115 Posts
Soggy, I agree with Chillyphilly. This is a notable achievement, you should really post the story in the forum separately. Lots of us will be interested.
John
  #304
Old 11-04-2017, 10:32 AM
fmertz's Avatar
Received 1,507 Likes on 1,057 Posts
Managed to go through all the steps and _added_ a flip key to my car. Car initially came to me with the original key and a separate fob. I did not dare hack the one key I have, so I went down the path of adding a separate new key, in a flip format. Ended up acquiring all the components separately (eBay) and put them together. Learned a great deal in the process. A GREAT deal. Contemplating adding another one.
A separate conversion path is described here, with a similar end result: diy-flip-key-conversion-without-reprogramming-guide-pictures-93167/
  #305
Old 11-04-2017, 09:11 PM
mhminnich's Avatar
Default Dent removal
Took a stab and removing a largish dent that I 'obtained' a few weeks ago. Used glue pull tabs and my slide hammer, and am generally satisfied with the results. It'll work until I get around to a repaint.
  #306
Old 11-11-2017, 06:28 PM
RDMinor's Avatar
Default Adjusted the headlights & swapped seat modules to test
Noticed the passenger side low beam was off a bit so I searched around the forum (the svc. manual is useless on adjustments)for some info. on where and how and was able to get both sides to agree. They may not be EXACTLY where they need to be but at least their both wrong to the same place<G>
Feeling triumphant, I then undertook to swap the driver's side power seat module over to the passenger side which hasn't worked since I bought this car 3+ years ago. Success #2. The seat motors are O.K. but the module has the predictable circuit board tracks that have been worn through by the case rubbing them so I guess I'll undertake some delicate nerve grafting next week to save a few bucks.
  #307
Old 11-12-2017, 12:47 PM
smoggyx100's Avatar
Default Replacing and repairing rusty rear wings angle wheel arches.
Having both rear arches cut out, the rust in the inner wheel arch cut out and rusty metal in the rear wings. All to be followed with a full respray. Looking at green pearl over the original meteorite.
Inner wing and rear of sill
Inner wing
Rear looking into boot. Its rottern around the grill too.
Shows the amount of inner wing that had to be cut out
Inside of outerwing.
  #308
Old 11-12-2017, 01:57 PM
michaelh's Avatar
Received 2,398 Likes on 1,555 Posts
Unusual as the rot seems to be confined mostly to the join between inner/outer wings. The inner sills look OK, as do the subframe mounts.
Good luck with the repairs.
  #309
Old 11-13-2017, 08:35 PM
Fairfalcon's Avatar
Default 97 XK8 conv.
Today I pulled out the power antenna to see why it does not work. Well one reason is that the wiring was disconnected. I think whoever put in the new motor for the hydrolic roof pump must have knocked it loose.... second is that the plastic strip inside the mast was broken. So I will order a new mast and it should be good as new again.
Mike in TN
  #310
Old 11-15-2017, 03:37 PM
Fairfalcon's Avatar
Red face 97 XK8 antenna
Well today I went over to Knoxville and got the new antenna mast from the Jag dealer there. Put it in and now everything works fine. Mast was $60 and took about an hour to fit.
Mike in TN
  #311
Old 11-15-2017, 04:51 PM
claudesr's Avatar
Default Checked OB codes
I have the dreaded yellow light and performance restriction warning.
OB reader tells me that it is the Knock Sensor (Bank 1)
Will have to pull the SC to change them (I will do both to save me doing it again in a few weeks or months when the second one will probably fail.
  #312
Old 11-15-2017, 04:59 PM
Gus's Avatar
Gus
Gus is offline
Received 2,213 Likes on 1,702 Posts
Think about replacing hoses at the same time.
  #313
Old 11-15-2017, 05:47 PM
claudesr's Avatar
Thanks Gus, good idea.
  #314
Old 11-30-2017, 04:00 PM
smoggyx100's Avatar
See here https://www.jaguarforums.com/forum/x...99-xk8-190365/
Orthodixie (12-11-2017)
  #315
Old 11-30-2017, 05:16 PM
XK8 Comfort's Avatar
Cleaned and lubricated parts of my XK8 convertible top latches. Thanks for all the instructional posts.
  #316
Old 12-09-2017, 05:54 PM
michaelh's Avatar
Refitted the ECM after a recap:
The Nichicon caps used in our ECMs have been superseded; today's equivalents are
UPJ1H100MDD1TA 10uF 50V 105c (x2)
UPJ1J470MPD 63volts 47uF 105c (x2)
UPS1A221MED 10volts 220uF 105c (x2)
UPM1H561MHD6 50volts 560uF 105c with the correct dimensions was on back order of ~15 weeks or so, so I used UPM1H681MHD6 50volts 680uF 105c. Electrolytic manufacturing tolerances are pretty wide (20% of nominal value) so the 680 will be OK.
Strange that there haven't been any reports of the 98 on ECMs failing due to leaky/dead caps, as they appear to use exactly the same values and types. All the ones I removed looked physically fine, although I didn't do any tests on them - the age alone is sufficient reason to swop out.
These are available from Mouser, but both US & UK wanted to charge me silly money for postage/UK VAT, so I won't deal with them.
No affiliation here:- I found Arrow Electronics (US) on Nichicon's website. They ship free and delivered in around 4 days across the pond, so I'd highly recommend them.
toaster (12-12-2017)
  #317
Old 12-10-2017, 02:14 AM
dibbit's Avatar
Why did you decide to replace the capacitors? Was there an issue with your ECM?
  #318
Old 12-10-2017, 03:59 PM
michaelh's Avatar
Hi Dibbit,
I'd pulled the ECM primarily to confirm the that everything was OK in there, and greenforest's attempt to repair his was the catalyst to do so for comparison purposes.
I had no ECM issues, but the age and similarity to the '97 meant it was worth a check. I haven't read of any issues with 98+ ECMs, but I don't want to be faced with repairing a damaged PCB for the sake of $5-$6 and a couple of hours work. Just seems like cheap insurance.
I did agonise for a while over the 'warranty invalid if seals broken' stickers, though
  #319
Old 12-11-2017, 09:37 PM
Johnken's Avatar
Good idea Mike. Those electrolytic caps are pretty old.
John
  #320
Old 12-12-2017, 02:26 AM
dibbit's Avatar
Hi Dibbit,
There are some threads on here with people who have had problems with the later ECMs (including 2001s like mine) - although it does seem to be the earliest that are most likely to fail. I suppose at some point the electrolytic capacitors are going to fail - I'm not sure I would be brave enough to do it as preventative maintenance though, even if my warranty did run out 15 years ago.
Quick Reply: The "What did you work on today" thread.
