I decided to do my upper and lower ball joints, inner and outer tie rods and my end links! Needless to say after about 7 hours total in 30-40 degree F temps, rolling around in the stones. I got my upper ball joint, end links, and outer tie rod on the left side only! Argh! I did manage to bend my ball joint clamp trying to get the lower ball joint. I also found that even though I watched several videos and have done several before, that my inner tie rods are the internal type! Argh! I don't have that tool of course. Oh well I guess I'll tackle the rest another day. Drrrrrrrrrr!
timeisrelative - did you pull the bellows down and look at the inner tie rod? I picked up a tool from Harbor freight for about 10-15 bucks to remove the inners - pretty simple job. The lower ball joints are a whole different story which I removed the lower control arm and ended up having to buy a 20T hydraulic press to install - quite the painful undertaking
Yeah I pulled the bellow down and went drrrrrrr because on mine the ball is actually recessed in the rack end. I even pulled the rack bushing to see if maybe there was a way to remove the end or something, but it looks like I'll need one of the tube type inner ball joint tools
Edit! I just thought about it and went oh duh! I had my wheels straight! Argh! What an idiot! I'll look into it on Tues. Duh!
Just finished doing the rest of my tie rods, end links and upper ball joints. I think both of my lower ball joints were replaced because not only did the nuts come off nicely, but both of them felt pretty good and they were the only thing up there that the rubber boots were still perfect on. We'll see, not that hard to get to them if they end up going out in a couple of years or so.
URO component quality always seems to be mediocre at best. I have installed various URO parts but never really trusted them. Just continue to keep an eye on that new reservoir....
rothwell, go down the page a bit on the regular Forum and look at Razorboy's write up on the plastic welder and give your reservoir a good seam around that leak area or the whole thing.
That would be interesting if it would still hold pressure and not leak, could be a quick fix for someone needing their car right away.
Thanks for the good picture of where.
Yesterday I decided to finally upgrade my dash lights from standard to LEDs. I watched Dr. Sam's video twice in the last week to make things go easily, then forgot to disconnect the 2 wire bundles powering the cluster. Since I was unable to fully pull the cluster out of the dash, I changed the bulbs in place, with the cluster tilted outward. Not the best methode, but using a small pair of needle nosed plyers, I finally accomplished the feat. Now the one dead bulb(behind the temp gauge) and all the others are shining bright. Checking the polarity of the LEDs, marking it with a pen, and installing as suggested with the '+' edge 'down' prevented trial and error replacement.
Thanks for the video, Dr. Sam, even if I didn't follow the entire procedure correctly.
Well I recently fixed the overhead map light console mount but now one of the bulbs blew! Bugger! Still chance to replace the bulbs with T10 LEDs (had in my box of electrical bits) Modern white lighting not low level yellow.
Easy job, but noticed the new light levels weren’t good as the new LED bulb were 2 faced and one LED light source faced up into the cavity.
Quick easy solution was to put a reflector (aluminium foil) over the top of the light fixing.
Got noticeably more light into the cabin approx. 50 percent more. Easy to just peel off to access the bulb in the future.
Good move. I have the 4 sided, but will try that next time I open panel. Started with 'blue' lites(didn't notice until installed), had to replace. Sexy, but not too effective.
Finally did the Headrest Repair on both Seats. Did not do the Splice. I cut the Silver End Piece off and removed the Sheathing from the End Piece. I then cut off 14mm of Sheathing off the Cable. Put everything back together and now both Headrests work. Now if I could only get rid of Air Bag Codes.
Wife didn't like the drive belt squeak in the first few minutes of the day (on my car, her car is fine). So, replaced drive belt idler pulley, tensioner/pulley, belt. Old idler pulley was not particularly free moving, new one is free moving. Easy to get to, quick. Reflexively borrowed a serpentine belt tool from O'Reilly's, don't really need it if you have a long ratchet and 12 point sockets.
Gratuitous picture of old idler pulley below.
Old idler pulley, bearing probably fixable but why bother?
Just completed replacement of timing chain guides and tensioners. Was a little apprehensive to start it up after engine all buttoned up, but engine started right up and purred like a kitten. Also resealed oil sump, replaced spark plugs and serpentine belt. Replace front sway bar links and bushings (access to sway bar bush on D/S easier with cooling fans and shroud removed). Glad the timing chain and guide replacement is done, now just waiting for nice weather to take it for a drive.
Finished cleaning/polishing/shining them all today in between long-winded expositions on automobile safety and steering wheels. Big merc is jealous. Should have moved him out of the picture.
