The "What did you work on today" thread.
Old 08-09-2020, 09:44 PM
stu46h's Avatar
It's been too hot around here to do much of anything but I put a new chain on my chainsaw today. I did move the Jag out of the garage to make some space to work. Does that count? We had some trees come down in Tropical Storm Isaias so I'll be cutting this winter's firewood as soon as the heat breaks. And replacing the chain is easier than sharpening the old one but I'll sharpen it anyway and have it ready to install when needed.
The following 3 users liked this post by stu46h:
crbass (08-09-2020), DavidYau (08-10-2020), Timeisrelative (08-10-2020)
  #682
Old 08-09-2020, 09:56 PM
XKHawk's Avatar
Replaced the coolant expansion tank, no more 'low coolant' warning. Nice!
The following 3 users liked this post by XKHawk:
crbass (08-09-2020), DavidYau (08-09-2020), Timeisrelative (08-10-2020)
  #683
Old 08-09-2020, 10:04 PM
crbass's Avatar
Seems like it counts, and it applies to jag parts too. That's the reason I have four sharp chains (all mildly distended from overenthusiastic/aggressive use on century old massive pines). It's always easier to buy the new part.
  #684
Old 08-10-2020, 04:43 AM
Sapphire Blue's Avatar
Pressure checked my "Get you Home" spare, instead of just the usual visual & squeeze. Found it to be 70psi under the recommended!
  #685
Old 08-10-2020, 09:00 AM
fmertz's Avatar
Received 1,505 Likes on 1,054 Posts
Hmm. Typo? I believe these should be inflated to 60 psi. In fact, that number can be read directly on the sidewall in this very picture you posted.
Best of luck, keep us posted.
  #686
Old 08-11-2020, 01:39 AM
Thanks for your sharp eye
fmertz.
Should of course read 40psi under inflated.
  #687
Old 08-11-2020, 04:20 AM
Timeisrelative's Avatar
I finally got my ECU back and installed it! So far so good!
The following 2 users liked this post by Timeisrelative:
crbass (08-11-2020), DavidYau (08-11-2020)
  #688
Old 08-17-2020, 03:17 AM
Default Replaced Bonnet Gas Struts
From a safety aspect decided it was time to replace the Bonnet Gas Struts on my XKR 100, it appears the old ones were still original from 1999.
SGS supply UK made equivalents which I've used in the past for the boot.
The following 3 users liked this post by Sapphire Blue:
BradXK8 (08-26-2020), DavidYau (08-17-2020), Timeisrelative (08-17-2020)
  #689
Old 08-19-2020, 08:41 PM
finally got around to fitting my new front rotors! No more steering wheel shake while braking!Yay! I also tried adjusting my parking brakes, but I guess I backed them off too far, either that or my cables are frozen! Drrrr! I also painted my Revolvers in graphite. I liked the previous color, but never could find out what it actually was. Oh well
  #690
Old 08-20-2020, 03:21 PM
Cabel's Avatar
I stared longingly at my XKR today, as it is still in the garage waiting on a rebuilt supercharger ordered back in late May.
The following 2 users liked this post by Cabel:
Timeisrelative (08-20-2020), zray (08-20-2020)
  #691
Old 08-20-2020, 06:18 PM
zray's Avatar
Received 1,666 Likes on 989 Posts
that has to be the toughest job of all.....
Z
  #692
Old 08-21-2020, 11:13 AM
Higgins's Avatar
The rear subframe and suspension assemblies finally ready to be bolted back to the body. Taken a lot longer time than expected to get everything in place. Most parts that wear have been replaced
The following 6 users liked this post by Higgins:
cjd777 (08-22-2020), DavidYau (08-21-2020), fmertz (08-21-2020), michaelh (08-21-2020), Sapphire Blue (09-12-2020), Timeisrelative (08-21-2020) and 1 others liked this post. (Show less...)
  #693
Old 08-22-2020, 03:11 PM
michaelh's Avatar
Received 2,389 Likes on 1,550 Posts
Did the second trans flush so we should be good for the next 30K or so. It does seem to get easier by the third time around. One bonus (probably the only bonus) of the 5HP is that it is possible to get the fill plug in without getting 3rd degree burns on the back of your hands.
Removed a good percentage of the interior in preparation for getting the headliner & rear shelf out for retrimming. The trim folks have promised that the new glue they use is super dooper sticky stuff so hopefully the lining won't start floating down again after five or six years this time around.
  #694
Old 08-23-2020, 09:07 AM
STLTHMSTA's Avatar
Oh my!! That is a beautiful thing! Too bad it's hidden most of it's life. TM
The following 2 users liked this post by STLTHMSTA:
michaelh (08-23-2020), Sapphire Blue (09-12-2020)
  #695
Old 08-26-2020, 03:08 AM
DavidYau's Avatar
Received 1,418 Likes on 755 Posts
Default VVT connector
Having R&R the car’s alternator, I hit a problem of a broken VVT connector.
Previously put in a temp duct tape/ shrink wrap fix but recently noticed a drop in MPG and sluggish drive. Plugged in OBD scanner and got P010 VVT prob Bank 1. Knew that my temp fix had come loose.
Jon89 pointed me in the right direction for the new part - an Airtex/Wells 1P1792 connector. My new bit came complete with pig tails for soldering in.
You can see how the old connector internals had broken loose and I can see the old white clip bit still in the VVT solenoid plug recess.
There’s no room to cut and solder wires without taking out air tunnel. So with my recent success on the Engine Coolant Temp. sensor connector, I immediately set about dismantling the new connector to re-use the existing pins.
Easy job then to just push the old wire pins into the new connector, push in the white clip and then had to clean out the broken plastic in the VVT solenoid plug recess. Job done in 15 min.
The following 3 users liked this post by DavidYau:
cjd777 (08-26-2020), michaelh (08-26-2020), Timeisrelative (09-01-2020)
  #696
Old 08-26-2020, 05:50 AM
Jon89's Avatar
Received 4,360 Likes on 2,851 Posts
Well done....
  #697
Old 08-26-2020, 07:04 AM
SamtheSham's Avatar
and I thought duct tape could fix anything......
DavidYau (08-26-2020)
  #698
Old 08-26-2020, 01:25 PM
flydutch's Avatar
Finished yesterday....
Cooling system fluid change, upper & lower hoses, thermostat, recovery tank-to-thermostat line... the Octopus was replaced in 2018, so we're good there!
Serpentine belt replaced.
Oil and filter changed.
Car always sounds and feels smoother when you've done good things to it !
what a mess! but it all came together okay.
  #699
Old 08-26-2020, 02:53 PM
Jon89's Avatar
Well done....
  #700
Old 08-28-2020, 06:06 PM
michaelh's Avatar
Removed a dead starter motor from the Peugeot 306.
The Haynes manual says "disconnect the connections from the solenoid, remove the three securing bolts and then extract from below."
Yeah, right. The page about dismantling the inlet manifold & TB first on the 2.0 must be missing from my copy.
Seized solid. I've never seen that on a starter before.
Still the best value for money and TCO ever over 18+ years.
Quick Reply: The "What did you work on today" thread.
