The "What did you work on today" thread.
Old 08-23-2021, 09:55 PM
zray's Avatar
Received 1,666 Likes on 989 Posts
At least you have a minion
The following 4 users liked this post by zray:
cjd777 (08-24-2021), crbass (08-23-2021), Jon89 (08-24-2021), Kev-P- (08-24-2021)
  #922
Old 08-24-2021, 06:19 AM
SamtheSham's Avatar
Remember "Murphy's Law" ('anything that can go wrong......'), and 'Murphy's Corollary', "Murphy was an Optimist".
Can I borrow your 'Minion'??
  #923
Old 08-24-2021, 06:45 AM
Jon89's Avatar
Received 4,360 Likes on 2,851 Posts
Guys, keep in mind that you must house, clothe, and feed your minions. Is the occasional need for a minion worth it to you? Think carefully before deciding....
crbass (08-24-2021)
  #924
Old 08-24-2021, 07:16 AM
SamtheSham's Avatar
Oh, thought I could borrow, and then send back to you...
Gotta help out fellow Jag owners???
  #925
Old 08-24-2021, 07:49 AM
crbass's Avatar
But, more importantly, the emotional price that must be paid.
  #926
Old 08-24-2021, 08:08 AM
Markel's Avatar
'' What did you work on today''..................................a different type of European recalcitrance.
My 1983 500cc 2 stroke Swedish fear maker.
  #927
Old 08-24-2021, 08:43 AM
Jon89's Avatar
^^ What's the story on that Buick Riviera?
  #928
Old 08-24-2021, 08:53 AM
Markel's Avatar
Summer daily about 3000miles so far this year......................got to have at least one reliable vehicle
The following 4 users liked this post by Markel:
crbass (08-24-2021), Jon89 (08-24-2021), Kev-P- (08-24-2021), Timeisrelative (08-27-2021)
  #929
Old 08-24-2021, 10:34 AM
Jon89's Avatar
What model year is that Riviera?
  #930
Old 08-24-2021, 01:18 PM
drmike's Avatar
I wanted to fit a new rear lower shock absorber bush but the nut on the big bolt that goes through it just span. Clearly either the nut or the bolt had stripped thread. I wanted to do it gracefully but after trying all sort of spannery tricks, I tried a dremel and when that failed I got the angle grinder out to cut the nut up. Being on the drive on my back didn't make it any easier. Four hours in all.
I assume some gorilla over tightened it and stretched the bolt and so the nut had nothing to grip onto.
Made me think about how careful one should be about tightening.
Ran out of time for the bush.
The following 2 users liked this post by drmike:
crbass (08-24-2021), michaelh (08-24-2021)
  #931
Old 08-27-2021, 01:11 AM
DavidYau's Avatar
Received 1,418 Likes on 755 Posts
Default Dale - been there, done that, got the T shirt
Originally Posted by crbass
I've learned that all jobs replacing sensors on the XK8s must invariably also involve replacing the fragile/friable connector ... and assorted other "entertaining" diversions. As it was today replacing the coolant temperature sensor, truly a 60 second job.
About a week ago, I went to replace a coolant temperature sensor and found the old broken connector RTVed to the sensor (see below). This necessitated about three days waiting for the "new" connectors from Mouser (ordered 4).
At this point, who knew that the Econoseal E J2 had an ASSY B and an ASSY D version that are the same except for the slots? So, lesson learned (thankfully the ASSY A and ASSY C versions must have disappeared with the last industry consolidation), I waited three days for the "new new" connectors from Mouser (ordered 4).
The "new new" connector perfectly fit the sensor I ordered from Rock Auto. So, I popped the pins in the old connector, installed them in the "new new" connector and prepared to unscrew and rescrew quickly.
Unfortunately, 25 seconds into the operation, coolant flowing from the hole, it became apparent that the sensor from Rock Auto did not fit the hole in the water rail. Hmm. There are two sizes of sensors for this?
So, disgusted, I sent a minion to Autozone who returned with a sensor that looked like mine. And, good news, the "new new" connectors don't fit, but the "new" connectors fit.
So, I popped the pins on the "new new" connector and installed the "new" connector and replaced the sensor.
So, 60 second job = 60 seconds staring at the old connector wondering how many broken connectors are left on my cars (afraid the answer is "all of them"), 1 minute looking in the electrical diagram to identify the connector, 2 x10 minutes looking for connectors at Digikey and Mouser, 2 x 2 minutes opening packages, 20 minutes popping pins and replacing connectors (18 min finding the right pin popper, 1 minute each popping pins), 20 minutes going to get new sensor (admittedly I sent someone, so it's not my time, but I could have had them plowing the back 40), 1 minute replacing the sensor.
Without counting the week waiting for connectors, that's 67 minutes for a one minute job. 67X actual/theoretical seems about right.
Out with the old
In with the 'new', not the 'new new'.
Crbass - know the feeling on this job. Link to my thread below.
https://www.jaguarforums.com/forum/x...nector-236737/
  #932
Old 08-27-2021, 10:05 AM
crbass's Avatar
David,
Fascinatingly similar experience. Interestingly, the connector in the coolant sensor I installed had no slots at all, compatible with both versions. So there is also that…
  #933
Old 09-08-2021, 07:27 AM
Tom Baker's Avatar
Things just went south with my daily driver (hahaha Airmatic) and now my backburnered nuisance "Engine Coolant Low" issue has become a frontburnered issue.
Per suggestion, I replaced the coolant cap with the OEM - it made no difference (other than lightening my wallet to the tune of $55).
I've checked the reservoir in the wheel well - it looks fine and has an appropriate amount of coolant and its cap is on firmly, so I figure next step is to replace the Coolant Overflow Tank & Sensor. Do we have a good guide for this process somewhere?
I'd also like to replace the hose leading to the wheel well - it's the same plastic as the little hose that runs from the thermostat tower to the overflow tank and I've snapped that before, so I'm thinking it's probably old, brittle and possibly cracked somewhere along its length... but I can't find a part number. Any suggestions on replacing this?
  #934
Old 09-08-2021, 08:26 AM
Jon89's Avatar
Who charged $55 for an OEM coolant reservoir cap? They are typically available online for $22 to $25. At least they were the last time I looked (several years ago)....
  #935
Old 09-08-2021, 09:26 AM
Tom Baker's Avatar
  #936
Old 09-08-2021, 11:17 AM
crbass's Avatar
Highway robbery. Is $22 from Jag in the UK. My local Cary Jag has it for about $27 if one shows up at the counter.
On the internet, is about $35 delivered from Harper Jaguar. (Also new OEM on ebay).
https://parts.harperjaguar.com/oem-p...-cap-mja4440ba'
  #937
Old 09-08-2021, 04:05 PM
michaelh's Avatar
Received 2,389 Likes on 1,550 Posts
^^ Ouch! At that price, I hope it came with lube...
It seems that the US dealerships add a hefty markup to Jaguar Heritage prices, which are what the UK dealerships would charge.
crbass (09-08-2021)
  #938
Old 09-08-2021, 04:09 PM
SamtheSham's Avatar
I jus replaced my coolant tank and a crossover line. Had been getting a "Coolant Low" light for a while with the tank topped off. Small leak in crossover line, so it went. Replacing the tank, now have a clean instrument panel(sort of). Float in the tank seems to stick.
  #939
Old 09-08-2021, 08:08 PM
Received 4,282 Likes on 3,702 Posts
Stant makes a replacement cap - got mine at Advanced auto for about $10 and still works fine
crbass (09-08-2021)
  #940
Old 09-08-2021, 08:49 PM
Tom Baker's Avatar
Any particular guide you followed for this?
It looks pretty simple (except tracing the crossover line back to the tank in the wheel well)
Quick Reply: The "What did you work on today" thread.
