The "What did you work on today" thread.
Old 12-18-2021, 04:43 AM
drmike's Avatar
I can't quite recall but I did manage to touch the top of the pump I'm sure to feel if it was running. If my pump was broken (and thankfully it wasn't) I was going to do what that guy in the link did. I thought removing the pump from the top was very hard and I don't have access to a lift.
  #1002
Old 12-18-2021, 04:53 AM
Pistnbroke's Avatar
I can get it up but the weather is against me and I have an owner from Texas on his way to see me so want to drive the car to investigate the grinding from the torque converter area.
  #1003
Old 12-18-2021, 05:04 AM
drmike's Avatar
Tell me about the weather, I'm not so far from you (well 30 miles) and today is dank. The Texan is the guy who asked about batteries and stuff?
I'm sure he's hardy enough not to need a heater
Grinding noises though - not so great.
  #1004
Old 12-18-2021, 05:06 AM
Pistnbroke's Avatar
He was born in Rugby where I live so coming to see his mum.
  #1005
Old 12-18-2021, 05:28 AM
drmike's Avatar
Nice. I bet doesn't bring his battery though.
  #1006
Old 01-08-2022, 06:04 PM
crbass's Avatar
Default Long Jobs
Bad news: About three weeks ago, I washed the car, polished the hood and snoot in preparation for ceramic coating the hood/snoot that had to be repainted in the fall after a surprise encounter with an itinerant box spring at high speed on the interstate.
Good news: All six of us in the house are now over COVID, and the two hour job was completed this evening. Hooray.
Temporary pinstripes make the hood 'pop'.
The following 5 users liked this post by crbass:
AFTERSHOCK (01-09-2022), cjd777 (01-08-2022), DavidYau (01-08-2022), Johnken (01-08-2022), Jon89 (01-09-2022)
  #1007
Old 01-09-2022, 06:01 AM
Jon89's Avatar
Received 4,360 Likes on 2,851 Posts
Well done, and glad to hear that your household's bout with Covid is now behind you. I hope the symptoms remained mild for all of you. It is indeed running rampant around here....
The following 3 users liked this post by Jon89:
AFTERSHOCK (01-09-2022), cjd777 (01-09-2022), crbass (01-09-2022)
  #1008
Old 01-09-2022, 05:43 PM
AFTERSHOCK's Avatar
Default New radiator installed today
I finally got a little spare time and installed my new radiator that was sitting in my garage for the last 6 months. Lol the car would only leak antifreeze on start up, about an once or 2 and stop, and sometimes it would not leak, hence why I procrastinated for so long. Lol install was pretty straight forward only had issues separating passenger side condenser was way easier to install the new one then take the old one out. Was about 2 or 3 hours total. Hooray
Old 23 year old radiator, hope the new ones lasts at least half that time.
The following 5 users liked this post by AFTERSHOCK:
cjd777 (01-09-2022), crbass (01-09-2022), DavidYau (01-11-2022), JimmyL (01-28-2022), STLTHMSTA (01-10-2022)
  #1009
Old 01-09-2022, 07:02 PM
szhilian39's Avatar
Did some cleaning. Removed the old stinky sponge under the rear seat and replaced it with some new materials.
Also, did some color restoration job.... seat belt buckle.
The following 4 users liked this post by szhilian39:
AFTERSHOCK (01-09-2022), crbass (01-09-2022), DavidYau (01-11-2022), STLTHMSTA (01-10-2022)
  #1010
Old 01-11-2022, 04:35 PM
szhilian39's Avatar
Before...
After...
The following 5 users liked this post by szhilian39:
AFTERSHOCK (01-11-2022), cjd777 (01-12-2022), DavidYau (01-11-2022), Nickel (01-11-2022), ozbot (01-12-2022)
  #1011
Old 01-11-2022, 05:12 PM
dfbender's Avatar
Originally Posted by szhilian39
Before...
After...
What did you use to clean it?
  #1012
Old 01-11-2022, 06:13 PM
szhilian39's Avatar
I used this, combined with a steamer, toothbrush, and microfiber towels.
AFTERSHOCK (01-11-2022), CA Jag (06-14-2022), cjd777 (01-12-2022), dfbender (01-11-2022)
  #1013
Old 01-11-2022, 06:33 PM
AFTERSHOCK's Avatar
great job and what a difference. Wow
The following 3 users liked this post by AFTERSHOCK:
2ndeagle (01-11-2022), cjd777 (01-12-2022), DavidYau (01-11-2022)
  #1014
Old 01-12-2022, 03:31 PM
fmertz's Avatar
Received 1,505 Likes on 1,054 Posts
Originally Posted by AFTERSHOCK
FWIW, the parts store generally carries an assortment box of coolant plugs suitable to cap this bleed nipple. I had a home-made contraption like that for a while and it eventually started leaking. Because of course it did.
AFTERSHOCK (01-12-2022)
  #1015
Old 01-12-2022, 04:10 PM
AFTERSHOCK's Avatar
I actually work at a hardware store Lol. The plug is a aqua pex plug for 1/2 pex line. It was the best solution I could come up with that we had. I will keep an eye on it now that you mention it though.
szhilian39 (01-13-2022)
  #1016
Old 01-13-2022, 02:21 PM
szhilian39's Avatar
Default Belt Trim Pin Fixed
I was using JB Weld and a piece of credit card. Now, the trim is firmly fixed without making any noise.
The following 2 users liked this post by szhilian39:
AFTERSHOCK (01-13-2022), artntek (02-28-2022)
  #1017
Old 01-22-2022, 04:34 PM
tsuppari's Avatar
Working with brittle cupholder hinge second time. First fix lasted two year. Now 'final metal solution'. Incredible brittle plastic; like flour after 20yrs.
Soldered piece of nickel/copper tube to 1mm metal sheet as a new hinge point.
Then epoxied it into cupholder. Now holder will last here and cupholder will break some other point
The following 3 users liked this post by tsuppari:
crbass (01-23-2022), DavidYau (01-26-2022), ozbot (01-28-2022)
  #1018
Old 01-26-2022, 12:38 PM
Flcat's Avatar
Default 2002 XK8 engine light
Hi I cleared an engine light today. The code was PO442, Evaporative Emission System leak detected. (small leak). Anyone have an idea for this DIY. Ty
  #1019
Old 01-28-2022, 08:14 AM
NorXKR's Avatar
Could be the fuel filler cap that is not air tight anymore. It is the easiest thing to try first.
  #1020
Old 01-28-2022, 01:57 PM
szhilian39's Avatar
Before...
After with a custom-made cup...
cjd777 (01-28-2022)
Quick Reply: The "What did you work on today" thread.
