what do connectors on these parts do?
LJA6190AC and MJA49490AG both include connectors/switches
I would like to know what these connectors do, what do they connect to but
My search has failed, am stumped
Anyone know how to find out what these connectors/switches do? or know where I can find it?
thanks
thanks
The first switch is located under the shifter if I am correct.
Link 1997 wiring diagram http://jagrepair.com/images/AutoRepa.../jagxk1997.pdf
the numbers have apparently evolved
LJA6190AC used to be JLM20304
MJA4940AG was MJA4940AF and before that MJA4940AE
maybe an older # will appear in google
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/720x455/2011_04_19_202812_zf_5hp24_j_gate_pic_notinpark_page_1_copy_8d6bb412592b4df3faf3bc2e35224e4aeec7f4a5.png)
so then on the pic above are the part numbers assigned correctly?
and
where on google do you find this stuff?
thanks
Thanks. Continue fiddling with this.
I have 3 problems
1) doors don't lock when moved from Park as manual says they should and
2) memory buttons work when in R or D as manual says they should not
3) and there is a click under the J-gate when stepping on the brake when not in Park as if car saying ok to move from park
so I keep researching not-in-park switch and the Body Processor Module
query
do these events generate fault codes that can be read with proper equipment?
I have 3 problems
query
Hi
Still struggling with this; sorry
MJA4940AG and LJA6190AC show up at
https://www.jaguarclassicparts.com/u...trol-automatic
items # 4 and 23; VIN xxx02000
would like to know what each of them actually do?
could failure of either cause drive away door locking to fail?
thanks
thanks
sjc1997xj6
03-26-2014 12:24 PM
cincinnati
04-08-2010 02:55 PM
