What do I need to know before changing some front suspension components?
I'll be doing some front suspension work in the holidays and I have a few questions. Among the items I will swap are the following:
Does any of the work to be performed require bolts to be tightened to specific torque values? If so, what are they? Will I need any special tools other than the spring compressors and a press to complete this job? I have a friend who is a mechanic that will lend me these to use to get the job done.
Finally, could anyone please provide me with the JTIS instructions for the replacement of the shock mounts, lower bushes, and sway bar links?
Thanks in advance
- Shock mounts (bought Welsh urethane mounts; they seem well made).
- Lower shock bushes from SNG Barrat
- Anti-roll bar links. Bought Moog problem solvers as they seem to have great reviews in general. Let's see if they're any good on the X100.
Thanks in advance
Grease? Yes, 1 place by rear drive shaft on each side, that's it. Someone can better describe 4 us.
parts: missing upper shock mounts, upper control arm bushing ( go to powerflex website for good picture of all bushes and locations).
don't forget to check stabilizer bars front bushes.
tie rods?
upper ball jounts(easy job)
lower ball joints (harder to get to).
I have to admit I don't recognize lower shock mount.
hope this helps, John
tie rods?
giandanielxk8 (11-25-2018)
tie rods?
tie rods?
No, no, I bought the upper shock mounts and the lower shock bushing. The other items you mentioned I will be replacing as my budget allows it. At this moment I'm changing the most critical items.
I imagine I have to jack up the car and remove the front wheels. Disconnect the adaptive suspension wires, compress the springs unbolt the upper shock mount, and then the lower bolt on the shock to get that out? The sway bar link is also only two bolts and it's out? Am I missing anything?
Have a look at the video embedded in post 16 in this thread:
https://www.jaguarforums.com/forum/x...-04-xk8-99805/
The spring is held in partial compression by the nut on top of the shock. Between the nut I mentioned and the lower spring mount plate the spring can only compress to absorb bumps. It is under tension still, that's why you use a spring compressor before you take that top nut off.
hope it helps. John
hope it helps. John
Get a good quality, safe spring compressor!
Make sure you have the lower shock joint properly lined up (rotated) with the upper mount tower bolts before releasing the spring compressors.
Make sure you line up the right set of sockets/supports to press the lower shock joint on the outer perimeter. Pressing the center protruding section will likely break the plastic insert. I used a cheap HF 10-ton press for this.
The other lube points are both ends of each of the rear half shafts (4 grease fittings total).
Best of luck, keep us posted.
The following 3 users liked this post by fmertz:
Wanted to be sure you know to use an air compressor (10gallons+) with an impact wrench to compress the springs. It'd be a job from hell to try to do it with a manual socket wrench.
FWIW, I always use (borrowed from aitozone) 2 sets of spring compressor at same time. Makes it much easier for me, cost = same, zero$$ to borrow.
John
John
giandanielxk8 (11-28-2018)
John
John
So I can confirm that the front springs will compress manually.
I covered my experience on all of what you are about to do in my working thread starting here. Hope it helps give some insight into the difficulty.
The following 2 users liked this post by rothwell:
giandanielxk8 (11-28-2018),
Johnken (11-26-2018)
Shoreguy
09-24-2017 09:44 AM
caldercay
01-14-2016 06:26 PM
sunchip
08-11-2014 05:37 PM
rscultho
07-14-2012 08:17 AM
