What is the dumbest engineering design on XK8/R?
The following 3 users liked this post by Rex:
Received 1,666 Likes
hey, don’t hate me, I didn’t make up these names.
in all fairness to the designers and engineers, these cars are twice over their intended lifespan. Most of the items mentioned here worked fine 10 years ago,
Z
The following 3 users liked this post by zray:
The one by the wheel is called an atmospheric tank while the one under the bonnet is called the expansion tank.
Z
Z
Jack
Y2KJag (06-19-2024)
Z
Z
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
(Although I do use a battery tender and drive frequently).
But if a battery goes flat in only a week then something is amiss.
For me, it’s the rear seat space. Perhaps the most recognised design compromise of the X100.
When I changed my fuel tank, I found space that could have been better used. The rear bulkhead (on a Coupe) could be 2.5 inches further back. It would need a re-profiled fuel tank and reduced area rear seat backs. However, this would place rear passengers farther back where the headroom is 1 inch less.
Also, the front seat-backs seem unnecessarily thick which reduces rear knee room. There is about 1 inch wasted space behind the internal airbag unit and lower headrest motor. Finally, the design of the front seat low-level mechanism necessitated a plate that reduces rear foot space.
Annoyingly, all of these design compromises were fixed by Porsche on their 911 many years earlier ☹
#28
Received 2,386 Likes
Poor choice of materials and no protection against water ingress. Water wicks along the pivot bolt and into the bushings. The bolt shank is unprotected so it can rust in the middle , and the bushing inner sleeve should have been stainless steel.
If the bushing seizes up it can cause the pivot bolt to rotate, which makes the bolt holes oval on a very expensive aluminium crossmember.
I was lucky when I changed them, but I've read some horror stories on here around getting the pivot bolt out.
I have it as a periodic maintenance item.
The following 5 users liked this post by michaelh:
cjd777 (06-20-2024),
Dr. D (06-20-2024),
markmywords (06-24-2024),
PKWise (06-20-2024),
Y2KJag (06-24-2024)
#30
#31
#32
Reading through these, there is a definite penny drop of - this was a cobbled-together compromise of a car, I get it. Its an almost bizarre mish-mash of parts old and new spanning 3 decades. Brand-new (too new) engine design. CANBUS. IRS from the 60s (one of the better features, mind). AC from Honda, I think. Various random honda parts. Mercedes transmission. Bosch power steering. Warmed-over XJS monocoque. Lacklustre infotainment and bolted-on satnav. but the seating position could most definitely have been done better, I mean the seats in the XJS are objectively better. The seats in the early XK8s with the fixed backs are at least thinner. Ultimately, Jaguar did not have enough money and time for this car and the X150 to me, now, represents a better realisation of what the XK is meant to be because it also got a totally reworked chassis.
A pox upon the designer of the rear diff housing esp on the convertible. Two days it took me to get that ******* plug off. Had to drive 75 miles to get a special tool, but I resisted cutting a hole. Changing the O2 sensors was a pig, not least because the fault code was a lie and it wasn't the fuel pump and I had to work that out. And even more ridiculously, that was a pleasant surprise - much as I hated changing those O2 sensors it was a relief not to have to do the fuel tank. According to the service history, my car had a failed fuel pump at 20k miles that got changed, so I hope I never have to...
Yet, I knew most of this before I bought an X100 with a 4.0 and still did it because - its a pretty car. I even sought out the earlier 4.0 (2002) because I don't like the body kit and front clip on the later ones. And I get an almost masochistic thrill out of daily driving one and working on it myself and keeping it on the road. I love how people react to it - "don't see many of those these days" "Is that the supercharged one" "that's a beautiful car". And its made me a better home mechanic. If it wasn't for this community and the resources here I would have sold the thing at a loss and cursed its name ever since.
So yeah, the best thing about the X100 is the friends you make along the way lol.
The following 7 users liked this post by Throwback:
cjd777 (06-24-2024),
markdpeter (06-27-2024),
michaelh (06-21-2024),
olddavidp (06-22-2024),
steve massey (07-10-2024),
and 2 others liked this post.
#33
The rear seats are big enough for young children and luggage. The car is much more practical than a 2 seater.
#34
The headlining in my 27 yr old Peugeot beater, however, is still as good as the day it came from the factory.
cjd777 (06-24-2024)
#35
Wasn’t meant to be too harsh on jaguar, I mean, if I didn’t like it I wouldn’t own the car and continue to make it better. I bought my car because I WANTED it, and knew EXACTLY what I was getting into, like I’ve said before; if you own an older Jaguar and aren’t prepared to work on it more than you drive it… it’s not for you ( unless paying top dollar to rectify every little issue is nothing), and if that’s the case, you should probably get a Maserati or Aston Martin or Alfa Romero or something, maybe a Bugatti? Those of us who own, fix, maintain older jags or even try to improve can all say at one thing(for the most part); we’ve taken it apart, accepted its inadequacy , said we can overcome and improve it, researched it, and made an effort to. Fail or not, doesn’t matter, we tried. That’s what matters, again, wasn’t trying to knock Jaguar or anything, I was just chiming in, didn’t think I would be called out on it, it was a harmless thread. Sorry if I offended someone but it is what it is, my coupe came to me with about 30 thumbtacks holding the headliner up…..
imean if you want a fresh suggestion what about the e brake lever position? Or the fact that it can’t sit more than three weeks without killing a battery? Group 49 agm at that! how bout the millions of parts upgrades throughout the vins?
nothing says I was supposed to be the next Aston Martin db like the xk8…. But to those of us who love and respect these…. Who the f…… cares?
cjd777 (06-24-2024)
#36
As Rex says, "we still love 'em".
Warts 'n all...
#37
Some parts definitely needed better engineering or more longevity and endurance testing.
However, it's amazing how robust some other parts are.
The 4.2 supercharged engine on mine, after 20 years, still runs like new. Also, although material choice may have been subpar in some areas, or compromises due to comfort in others, if compared to some of the stuff being sold today, I'd say we're pretty good. These cars do keep us busy, but they don’t become complete jalopies necesitating the junk-yard or a rebuild at 200k.
At least we don't have plastic oil filter housings, plastic timing covers, or plastic anti-roll bar drop-links (I'm looking at you, BMW and Stellantis cars).
michaelh (06-24-2024)
#38
#39
A number of people cited plastic parts, I agree they suck. I have had to make many workarounds and try to rebuild or refashion them, but I consider those more bean counter issues than engineering issues. Those shmucks saved a few hundred on parts on a $100k car that was destined to be a classic, what dopes.
I
I
#40
Not sure the frustration with failing parts and aging brittle plastic bits would be much different with most luxury cars of that era. Each has its own shortcomings. Remember the XK8 “evolved” considerably over its production run. That said, I still prefer the earlier X100 styling better. The design remains a “Wow, that’s a beauty” head turner after 25+ years!
