What is an easy way to put on new rad hoses?
I have run into this issue before trying to install new radiator hoses, or any hose under the hood. When I put on the rad hoses on the Jag it was a B&tch putting them on as the hose inside was dry and the part on the rad it went on was dry. What can you do to put them on with more ease?
I ask this because I am about to put on my octopus hose and with that new hoses being new will be unstretched to get on the fittings. Is there a way to make this easier???
Silicone spray as thats its primary use.
i just did my lower rad hose and just getting the clips on and off was a job in itself. they are so hard to clamp with pliers and are always in tight positions so you cant get to them easily, i ended up clamping them up then cable tieing them then sliding them in position and snipping the cable tie.
took me over 2 hours to drain the coolant and change the 1 hose
Prior to applying silicon to the inside diameter of the hose and the outside diameter of the fitting it's going on to, heat the end of the hose with a hair dryer. It will slightly soften the rubber and actually expand the inside diameter a tiny bit.
I used this technique when work on boats; nothing is accessible, and everything is difficult.
Tell me about it. Like i said if you get a thick cable tie and clamp it with some big pliers then put the cable tie on and then slid it on your pipe before you start its very easy. All you need to do is then snip the cable tie. Took me an hour to figure thats the only way with out special tools.
I bet thats why people use jubilee clips as they are simple but not as effective as the proper clips jaguar use
aholbro1
08-05-2021 05:02 AM
deanh
09-06-2015 08:20 PM
