What exactly are the faults with the x100 xkr with the 4.0L?
What things will I need to change to keep my x100 xkr running for a lifetime? I have almost new xkr silverstone with 6k miles on it. Going to change out the tensionors in the next few weeks or so. The tires are only two years old. The previous owner maintained the heck out of te car. So I imagine the fluids are not terrible, but going to check them out. What else do I need to address in order to keep it running like new?
Low miles doesn't necessarily guarantee longevity or reliability. Scheduled servicing is on a miles or time basis and, with your 6K miles Silverstone, should have been done annually.
A check through the FAQ's at the top of this section will show that the major issues members experience with the 4.0 litre are:
1. tensioners
2. cooling system
3. transmission
Regardless of low use, rubber components will deteriorate over time. Tyres should be discarded as the rubber dries and cracks start to appear. With our UK climate, this is typically around ten years but higher average temperatures reduce this considerably. Your two year old tyres will have quite a lot of life left in them.
Similarly cooling hoses are time limited. Much of the cooling system is plastic and Expansion Tanks are a regular fail (as is the level sensor in the base). This is probably the result of repeated heating and cooling cycles but may also prove to be a factor of time elapsed. Only time will tell!
The suspension has a lot of rubber bushes / metalastiks. These may not be worn but will almost certainly be hardening on your Silverstone by now.
If you are considering very long term ownership then trim items are usually the first to disappear from a manufacturer's inventory. Anything damaged or sub standard should be replaced before it becomes irreplaceable. This is even more relevant to a limited edition such as the Silverstone.
1. tensioners
2. cooling system
3. transmission
1. tensioners
2. cooling system
3. transmission
1. tensioners
2. cooling system
3. transmission
Good point on getting things fixed now. Do you know if they carry the speaker grill covers for the tweeter by the door? Also the A pillars fabric is starting to sag.
Sorry for any typos, I'm sending this from my phone.
Mike
Thanks,
Mike
You can get the A-pillar cloth at any decent fabric store or from an auto upholstery shop. It's really not expensive and you don't need much.
Rev. Sam has a video on how to change it out yourself (pretty simple). Here's the link:
scooternva
19
10-27-2015 02:14 PM
