What is the ground clearance on a standard XK8/XKR
#41
UPDATE
New Adamesh front springs installed now.
Front ground clearance raised by 50mm ( 2 inches ) from 90mm to 140mm. Both front and rear end is now lowered by 25mm' ish.
I was a little worried about what this would do to the look of my car, but honestly: it's still a good looker isn't it
The comfort of the drive is VERY much improved. These stupid low Majestic springs where really bad for the car.
I love the car even more now and hereby say THANK YOU to all who contributed in this thread
A few pics from the proces and the mandatory "before and after" photos.
Carsten
Before
After
Carsten
Before
After
toaster (04-27-2018)
#42
Received 6,315 Likes
Supersprint (04-27-2018)
#43
The following 2 users liked this post by fmertz:
GBCat (04-27-2018),
#44
#48
Supersprint is way low!
Supersprint,
Your front fender was setting about 1/2" below the top of your Tire, when it should be about 1/2" above your Tire...It appears you have changed the Springs now as it looks about the same as mine now! They should always set where the Fender is about 1/2" above the Tire... My XKR has the Handling Package and 20" Montreal's.....And I'm assuming your Wheels are 18" Centuar's but either way for drivability, you need about 1/2"...
Billy Clyde in Houston
"Click to Enlarge"
"Click to Enlarge"
