What happened to my 2003 ZF6 transmission?
#41
It's been a while since my last post. I needed to take a break from the issue and clear my head. Here's what I've done since my last post. I went over the speed sensors, wheel bearings and rings a second time with no issues found. I took it to an indy transmission guy with no experience with ZF units. He said right at the first hard shift, this isn't a mechanical issue. In his opinion, it's electrical. Take that for what it's worth. This coming week I have an appointment at a Jag dealer to have the transmission flashed and adaptions reset. It's the last thing I can think of. I'll have them check the connectors and confirm the proper fluid level before the service. Right now, I'm driving the car without faults. I start out in manual 3 and shift into 4th with no throttle. The only time it'll fault, is when I shift into 4th going up an incline. Still baffled by all this. Hopefully the dealer can sort it out.
#42
#43
Read thru the entire thread and did not see if you replaced the connector sleeve. I saw where you did check the connections. I ask this as when I changed my fluid I replaced the sleeve
and did not get it pushed in all the way. This after driving a bit started to throw codes. I removed the plug and found hydraulic fluid on it, Cleaned it and it would be fine for about a month.
I finally took it to a shop to have the sleeve checked and sure enough it wasn't pushed in all the way. Have not had a problem since.
Steve-in-ct
09-10-2016 04:31 AM
LoveForTheS
10-16-2012 04:29 PM
LoveForTheS
10-01-2012 06:47 PM
jya
05-12-2009 01:15 PM
