What hose is this?
What hose is this beneath the air intake box? What is the part number? How do I replace it or stop the leak?
It is leaking oil (looks like motor oil?) onto my sway bar and control arm bushings thereby completely desintegrating them.
Also, I was advised to ask the forum about using 5W-50 oil vs the 10W-40 oil I'm using. Is that a good idea?
Orthodixie (02-17-2018)
Looks like the "quick disconnect" fitting on the power steering return hose. You need an inexpensive air conditioning tool to slide over the line and unlock it. Mine leaked, and after much research here I replaced with a barbed fitting and hose clamps as the expensive factory replacement hose comes with the same low quality disconnect you have now................
The following 3 users liked this post by tdshepard:
![MettleAir 129-5-1 PK 5/16" ID Hose Barb Mender/Splicer/Joiner/Union Fitting Brass Tubing Hose Adapter/Coupler: Garden Hose Parts: Amazon.com: Industrial & Scientific](https://www.jaguarforums.com/forum/images/misc/amazon_icon.gif)
Available at any automotive parts store. You will need the tool to un latch the current fitting. You will slide a short piece of new hose over the steel line. Cut off the Jaguar hose just past the leaking connector. Insert barbed fitting into return hose and your new short hose. Use worm drive hose clamps to secure everything. (measure the o.d. of the steel line and the i.d. of the Jaguar return hose to determine what barbed fitting to buy) Also get a liter of Dextron III to top off your power steering.
Available at any automotive parts store. you will need the tool to un latch the current fitting. you will slide a short piece of new hose over the steel line. cut off the Jaguar hose just past the leaking connector. Insert barbed fitting into return hose and your new short hose. use worm drive hose clamps to secure everything. (measure the o.d. of the steel line and the i.d. of the Jaguar return hose to determine what barbed fitting to buy) Also get a liter of Dextron III to top off your power steering.
The following 2 users liked this post by SteveJacks:
giandanielxk8 (01-19-2015),
I think 3/8. Check out here, and within this post is another link to a forum members album with good pics.
https://www.jaguarforums.com/forum/x...ng-leak-67615/
giandanielxk8 (01-20-2015)
Could anyone show me a picture of the quick disconnect tool I have to use? Cutting the non rubber part is not feasible to me.
Never mind, I bought a random one of the correct size and then I just fixed the hose. Pretty easy if you have the right $5 tool.
mikiep
12-20-2019 07:37 PM
Pristine97XK8Convertible
04-28-2017 11:08 AM
