What is leaking into the trunk??
I noticed on my just purchased 2001 XK8 convertible 51K miles that there is some sticky fluid in the bottom of the trunk under the battery. There are some drops on the garage floor. Could it be leaking from the pump area and if so is this a major repair? Any help is much appreciated.
if that much leaked out to pool under your battery, your hydraulic top reservoir should show very low, check that first. If its between high and low marks, check that off your list. I'm gonna go out on a limb and say that previous owner spilled something in your trunk, and only surface cleaned it... not going deeper under the battery. I mean...would you?
Use this link to my page it has instructions to get to the pump http://www.gusglikas.com/AutoRepairJ...esRelValve.htm I hope this helps!
al_roethlisberger
09-09-2015 09:14 PM
