What Sensor is this???
That isn't a sensor. It is the "Part Load Breather" connection. If it is leaking the possibility is that the O-Ring is gone or the breather fitting has a crack. The purpose is to vent the engine blow-by back to the throttle body. Yes it is a source of vacuum leakage. You will need to remove it and examine the connector for cracks and the interior o-ring for damage.
We can help you with the info to replace it if necessary.
To remove the fitting you will need a U shaped tool that is insert to push the 2 straps outward to release the connection. If you don't have one on the fitting you can use needle nose pliers inserted and spread them out to push the straps outward.
Thanks. This is on a friend's car who has had the typical p0171 and P0174. He runs at about +19 LFT on both sides when just cruising at any speed and clearly gets to +25 without much effort. NBcat, Brutal and Motorcarman all think it is a large vacuum leak.
What I noticed was a clear indication of an oil film coming from there, not super heavy, but enough to leave a clear indication. The problem I also noticed that will be interesting is that one of the tabs you mention that you pull apart is broken and so any tension or release of tension on one side will be difficult. How does one get it off, if one of the tabs is broken? Could the broken tab be a cause for the leak? Also what is the actual name for this from jags standpoint. Alldata does not seem to know the part.
Tom in Dallas/Plano.
Jazzwineman,
Part Load Breather part no. #AJ84879 - probably a cracked as it's plastic and been baked in the engine bay. Maybe it's blocked,
Check out this recent thread
https://www.jaguarforums.com/forum/x...eather-221250/
Should be able to gently pry it loose even with a tab missing. Be gentle as it's easily cracked and to replace it will need the supercharger, and the air inlet manifold to come off. Some just fix the area around the connection (check thread link post #4 by Johnken).
Jazzwineman,
Tom
No- I sent you a pm to explain why . I just did not want to walk through things that I had already done- in a multitude of posts and then in pm with NBcat, Motorcarman and Brutal.
If you can tell me the answer to this I would appreciate.
T
T
T
T
I know there are some issues on the rear of the car where the canisters are, but could this piece be the cause of both issues???
TBB
The oil around the part loader breather connection tells you all. It is leaking vacuum. The tee to the throttle body is the same as the cam cover connection. The connection to the evap valve is a rubber hose. The leak at the cam cover connection will cause the evap system to malfunction which in turn is going to cause the canisters to saturate and fail. The best solution is to replace the part load breather hose, clear the DTC's and then see what returns before tearing into the evap system.
Replacing the hose is a labor intensive endeavor.
TBB
Hmmmm duct tape? Nah it doesn't like oil. Unfortunately there is no easy method. You have to strip off the supercharger and the intake manifold. That puts in the while I am this far into it I should replace the heater feed and return hose under the manifold, as well as any other hoses that need to be removed. Maybe injector seals, change the supercharger oil, etc, etc,
Sorry but no easy fix.
Go to SNG Barratt.com and download their free parts catalog. It has great pictures of the systems.
T
Jazzwineman,
TBB
lcyoung
01-14-2011 01:29 PM
