What is towing eye-bolt thread size?
You need to search this site for "tow eye", and look through the results, like this one:
tow-eye-source-20-mm-134657
I used 3/4"-10 thread, it worked.
USA 10 thread is identical to metric 2.5mm
3/4" is 19mm, but original tow eye has 10 working threads, mine went in probably 20 turns.
I'll go to junk yard and check all Jags there. I go there anyway about twice a week.
Thanks for all responses.
Let me know about BMW, Mercedes and other European cars sizes please.
Be careful with the tow eye under heavy load, like hauling up on a tow truck.
If your 3/4" (19mm) tow eye tears loose from your car then good luck with the repair bill.
The overall diameter is smaller (19mm vs 20mm) so it will likely strip out the hole/bolt and fail under heavy load.
"USA 10 thread is identical to metric 2.5mm"
There is no identical correlation between SAE and Metric. They might have similar dimensions but not IDENTICAL.
Make sure there is nothing behind the car when pulling it up on a flatbed tow truck.
bob
bob
bob
bob
USA 24 thread = 1"/24=25.4mm/24=1.04mm[ounojnozb
-------12-------------------------------------------2mm
Received 6,307 Likes
philwarner
02-02-2016 10:54 AM
LeapingCat
Mark V - X 420G
02-22-2014 12:39 PM
FS[SouthWest]: XK towing eye HJA4333AC 20X2.5mm 97-02
motorcarman
09-04-2013 07:11 PM
TopHatChef
General Tech Help
03-04-2012 02:06 PM
