What type of unleaded petrol are you using in your Jag
Hi
I have my 2000model XKR and also run a 2010 5.0L XJ
I'm just curious as to what type of unleaded petrol people are using, whether it's the standard 95 RON or the Premium 98 RON, and anyone's noticed any difference.
The reaon for this post is that I've been running my XJ for 12 months now using the standard unleaded with no thoughts of using anything better.
When I recently purchased the XKR the previous owner who had it for 7 seven years had been running it on the Super Unleaded and recommend I carry on doing so.
Your views on this and what you use will be appreciated.
Kind Regards
Rocky15
Kind Regards
Rocky15
Received 2,263 Likes
Jaguars are calibrated to use the fuel available in the country of sale.
Here is the UK, the recommendation for both of your vehicles is unleaded petrol 95 RON or higher. Given that 95 is the readily available standard, I wouldn't think of using anything other.
I've occasionally used 98 RON in a number of Jaguars with no discernible difference other than the cost. The only time I do notice a difference in performance is with the E10 on the Continent where there a marked drop.
The difference is the Ethenol content which I think is at least 10% in the US rather than 0-5% in the UK (not sure about Europe). Ethanol is basically bad for all sorts of bits - there's much been written on the subject already, here's some info for older cars.
Fuel Information
Fuel Information
My '99 XK8 4.0 in the US requires premium fuel, 91 octane of higher. Regular has an octane listing of 89. As this engine has a high compression ratio and the fuel here in the states ( my opinion ) is poor ( bare minimal federal detergent requirements) , I use 93 octane premium. My XK8 drop top is a spare vehicle, little mileage per year and I'd rather not take the chance with either 89 or the 91 product. Rich
Since I stopped using Tesco 99 ron my error P1033 messages have stopped (P0133 sensor circuit slow response bank 1 sensor 1) . This might be complete coincidence. But I was told that Tesco buys their fuel off the military and its full of additives which play havoc with things.
I'm no expert and this may not have a baring on fuel used. Just saying.
I just use regular 95 now with no trouble.
Rule of thumb
95RON = 91 AKI
98RON = 93 AKI
Your car was built to operate on 91 AKI. Anything higher, as in the OP's case, is a complete waste. Octane rating number has nothing to do with with the volume or type of cleaning additives.
A few years ago the Southeast US experienced a severe shortage of anything other than 'regular' fuel that lasted several weeks. During that time I researched octane and engine requirements and came to a conclusion.
The Jaguar design with knock sensors measure pre ignition 500 times per second and adjust the timing accordingly. Five hundred times 60 seconds is 3,000 rpms.
I think that means that between the sensors and the ECM pre ignition is managed at the expense of power produced.
Bottom line is if you expect to develop the advertised horse power use the recommended octane. If you drive like I do 89 regular is perfectly adequate with absolutely no negative affects on the engine. I rarely hit 3,000 rpms.
Mikey (12-07-2015)
I don't quite follow your logic of the significance of 3000 RPM. At that speed, each cylinder would fire 1500 times per minute or 25 times per second. If a knock sensor samples at 500 times per second, it would 'hear' each detonation (not pre-ignition) event 20 times. Plenty of safety margin.
On the other hand, there is a measurable and repeatable increase in MPG
when using premium. With a price differential between regular and premium,
the resulting MP$ can be competitive.
It's a have your cake and eat it too scenario.
Then again, I run down the highway with sport+4 because the instant
throttle response is nice. No different than if I really had a 3.58 rear.
Premium fuel Required
Yes, here in the States, Octane levels are the only gauge we can go by. My owners manual as well as the fuel ( petrol) door on my vehicle also states Premium Required.
As per John W from Wales stated, Europe uses 0% to 5% Ethanol. In my State, 5% is required with 85% Ethanol available. No option.
Even at a 10% Ethanol, fuel mileage as well as performance is greatly, greatly reduced when the fuel is new/ fresh. Ethanol not only absorbs moisture, it attracts moisture with time. The older the fuel the more moisture. Try it with E 85. Gotta be a 30% loss in mileage. Not to mention corrosion with fuel lines/ poly tanks, etc. The Feds are pushing for 15%. Anyone who has a boat knows the problems Ethanol is causing.
Me, I will continue to use the highest octane at the busiest stations available.
My owners manual also states use only fuels which contain detergent additives.
Fuel I use has 5 times federal ( US) requirements. Meaning. Minimal detergents with higher carbon build up with most fuel sold. Rich
The OP is in the UK where the octane rating is expressed by the Research Octane Number (RON). North America uses the Anti Knock Index (AKI) number.
Rule of thumb
95RON = 91 AKI
98RON = 93 AKI
Rule of thumb
95RON = 91 AKI
98RON = 93 AKI
Again, detergent levels have no connection to ethanol content or octane ratings.
