Wheel alignment?
sweez (05-10-2017)
Received 2,192 Likes
Absolutly get it aligned because when you change the ride height(you did with new upper bushings)this changes the camber which always changes the toe. Yes camber is not adjustable but any time you replace suspension pieces you need to realign the car period... And alignment is always cheaper than tires
Brutal (05-16-2017)
Brutal is totally correct. You HAVE to align it because the toe will be off.
Unless the tierod jam nuts are rusted on or stripped, the guys in the shop will be high 5ing each other because an X100 is the most simple alignment, ever... It will go up on the rack, the guy will wrench on it for 2 minute, it will come off the rack... $100 please.
