Wheel spacers and lowering springs
#41
#43
The Goodridge 38101 fit the fronts perfectly, but do not fit the rear. The rear lines are the correct length but they terminate with a male end and the XK8 lines terminate with a female. I used a female 10mm/1 bubble flair to bubble flair adaptor and made an attachment system with a washer and a clamp. It's not pretty but it works ok. When I can get the correct lines for the rear, I'll replace what I have. I've driven the car about 100 miles with this setup and there are no leaks.
fmertz (03-06-2017)
#44
#45
#46
That's a good question. I'm not sure if this was a mistake in the packaging, but my Goodridge lines only came with 4 washers in the package. It has banjo bolts for all four lines and needs two washers for each line. I had to buy washers to use on the rears. I went to AutoZone and they had one package of washers that were the correct size.
fmertz (03-07-2017)
