Wheel spacers and lowering springs
Old 03-03-2017, 10:30 AM
fmertz's Avatar
Received 1,512 Likes on 1,060 Posts
Nice. Can you share what you did for the brake lines?
  #42
Old 03-03-2017, 11:02 AM
jeje's Avatar
Finally, what is the spacers dimension ? 20mm?
  #43
Old 03-03-2017, 08:50 PM
johns55's Avatar
The Goodridge 38101 fit the fronts perfectly, but do not fit the rear. The rear lines are the correct length but they terminate with a male end and the XK8 lines terminate with a female. I used a female 10mm/1 bubble flair to bubble flair adaptor and made an attachment system with a washer and a clamp. It's not pretty but it works ok. When I can get the correct lines for the rear, I'll replace what I have. I've driven the car about 100 miles with this setup and there are no leaks.
fmertz (03-06-2017)
  #44
Old 03-03-2017, 08:51 PM
johns55's Avatar
The spacers are 25mm. The rears look like they would fit without the spacers but the front has to have them (with 18" Double Five wheels).
  #45
Old 03-06-2017, 09:27 AM
fmertz's Avatar
Originally Posted by johns55
The Goodridge 38101 fit the fronts perfectly.
One more thing: Did you have to also buy banjo bolts (and associated washers) to fit the lines to the calipers, or did those come with the lines? Thanks.
  #46
Old 03-07-2017, 05:10 AM
johns55's Avatar
That's a good question. I'm not sure if this was a mistake in the packaging, but my Goodridge lines only came with 4 washers in the package. It has banjo bolts for all four lines and needs two washers for each line. I had to buy washers to use on the rears. I went to AutoZone and they had one package of washers that were the correct size.
fmertz (03-07-2017)
