When Jaguar says you must have a new engine
Received 2,193 Likes
Ide go into the cylinder with a bore scope before i tore the head off. you can see the valves, and check the bore for scoring, on my Nissan engine I even saw where the top ring broke. I hate when ext warranty companies want tear down, because if they dont see a broken part they use that as an excuse to bail on repairs leaving the customer with teardown expense and repairs. I always push for approval based on diag without a teardown. And no warranty is a jaguar warranty other than the initial factory one. Select is the best but is still admined by outside company. So i jag extra mile<<<pos hate them. Factory times and they will pull this crap. We no longer sell this because of it. Easy car i like the most witht he least issues, but when youre dealing with a big bill they want conclusive evidence as many do and you as a cash paying customer would/should too. I have seen techs recommend a engine when it realy wasnt needed they just didnt want to got he extra mile to verify. Then again when i get to a point that i feel there is really engine damage i recommend 1 too. And yes its a remanned engine but "new" for the car. Dont get stuck on verbage. As motorcarman said. About the only time youll get a new engine/trans is on a newer car that for some reason failed.
Arland Green (12-14-2012)
Paul Pavlik-
Was your Steve an African-American? The Steve at Field's is- maybe the same one? Thx for the good word. This flusters me, as I hate feeling like I'm getting screwed on a deal, and the caveat of 'if it isn't carboned up' does not make me feel liike I have a complete warranty as advertised by Field's. When I get my cat out of the hospital, we should maybe get together and compare iron. The only other XK series cars I've seen in Miilwaukee are a pacific blue XK8 convertible, a silver XKR, a gold over gold XK8, a salsa red with tan top XK8, and a black/black XKR. None of these were coupes.
Steve installed the Mina Rear Lowering Springs that I provided and also the Thicker Axle Shims to compensate for the changed Rear Camber.
The people at Jenkins are very friendly and easy to deal with. However, as a Jaguar Dealer. their hourly labor charge is substantial. But I considered it worth it as the work was done carefully and correctly.
One item that concerns me is the statement that one Coil fires two Cylinders in the Jag. Just not true, each Cylinder has it's own Coil. Maybe just a mis-statement.
I'd like to see your car after the work is complete and you could see how mine looks "In Person". You can PM me and we'll get together. I live near Mayfair Mall in Wauwatosa.
Maybe I am ignorant, but shouldn't a carbon build-up increase compression?
Unless it is preventing a valve from closing. And couldn't you check this by the leakdown test or just supplying compressed air to the cylinder at TDC and seeing where it leaks from?
Or as suggested with a borescope. Heck, I bought one of those goose-neck inspection camera-recorders from Harbor Freight. $150. Its great for looking into the cylinder through the spark plug hole. You could also feed it through the intake manifold. Exhaust side would be a little more difficult.
Thanks guys.
#28
Received 6,330 Likes
The following 2 users liked this post by Norri:
Arland Green (10-18-2012),
JSC (10-18-2012)
The news came back from field's Jaguar today- the engine has been Terrracloeaned and deemed carbon free- same low compression in cylinder #2 exists. Tomorrow they wiill remove that cylinder head and inspect the internals to the head- valve spring, valve, piston top. They claim not to have a bore hole scope so that cannot be done. In any event, it will be back to will their warranty cover or no?
#30
A bore scope with camera can be purchased for 150 USD. I purchased one from COSTCO and have used it during replacement of a rear window regulator. I would offer to buy one for the shop to avoid potential teardown costs.
Also would question a shop doing engine repair work w/o adequate tools.
#31
You're welcome Arland, well that rules out "carboned up".
+1 on the borescope, they are cheap enough these days and $150 is a lot cheaper than labour costs to remove a head.
I just remembered my old mechanic in Perth had some special adaptors with the thread of a spark plug on one end and a quick-connect for a compressed air line on the other. He used them for replacing valve stem seals without having to remove the head (pressurise the cylinder, stopping the valves from dropping). Perhaps something like that could be used to determine where the leakage is coming from? If you hear the air leak through the throttle body = intake valve, out exhaust pipes = exhaust valve, in the oil filler = piston ring / cylinder. ?
#32
Field's Jaguar in Milwaukee performed the Terracleaning of my 4.2 AJ59 SC engine and it showed no improvement of comprression on #2 cylinder; they conclude it will then be a warranty situation and are taking tthe head off for inspection today. Should know soemthing after tomorrow and then will be the real post. Sorry, but trying to keep up with this event and driving another car in the mean time, courtesy of the dealer.
#33
#34
Fellow contributors-
I feel liike a lamb before the slaughter awaiting the decree from on high about whether my Jaguar warranty will actually warranty what it says it will when there is an unexpected low compression in one cylinder preventing me from renewing my vanity plates "MY XKR". Today should be the day when I know something from the dealer's efforts to inspect the head. Next- I will need to wait with baited breath for the Jaguar Technician-at-large to come to Millwaukee to make his concurrence or denial of the findings as to coverage. The whole process, to me, is not as advertised and 'we are less than amused'.![Confused](https://www.jaguarforums.com/forum/images/smilies/confused.gif)
Thanks to all of you who have responded- it is a feeling of being a part of a greater whole and a greater good and is strongly positive.
![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
#35
#36
Originally Posted by Arland
Thanks to all of you who have responded- it is a feeling of being a part of a greater whole and a greater good and is strongly positive.![Icon Beerchug](https://www.jaguarforums.com/forum/images/smilies/icon_beerchug.gif)
#37
I got the official word from Jaguarr US that they will do the following:
1. fix the bent valve in cylinder number 2. Shave the head and reinstall.
2. Open up the other head and repair two valves there causing 95 and 120 psi in two cylinders they have discovered are also low in compression.
They are saying this after telling me all cylinders were good except number 2- it was on the #2 cylinder head only, not both. Jaguar has said they wiill pay all repairs.
Their caveat is that if there is something more serious than valves in the other head, they wiill just replace the engine. And JAG has given me a new Land Rover to drive for the 2 weeks they think it will take to fix.
![Icon Stooge](https://www.jaguarforums.com/forum/images/smilies/icon_stooge.gif)
#38
#39
#40
Norri-
Yes, They say they will pay all costs for whatever needs too be done over and above the $500 deductible. So, at the worst I'll have what I'd call on an airplane engine a top overhaul. Then I'll take my new UK Hide Co. 55 ft2 hide over to the leather fitter and get my two Recaro seats reupholstered and then hope I can drive it before putting it up for the snow season. I also plan to follow the Forum's advice on reconditioning my top. I hope I'll see the difference when the negine work is done, because I'm dumb enogh to tink it was running fine when 3 cylinders were off!!
