Where to buy Brake Rotors
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
My 06 XKR with Brembo Brakes needs Rotors all around. I like the Cross Drilled ones. If been searching all the Vendors that I know, SNG Barrat was the only site I could find that offered a complete set. Where do you guys shop for after market Brake Parts? Also I was going to replace the Caliper Mounting Bolts, but can't find them listed anywhere?! Where do I look?
I am not affiliated with them but I have used Welsh Enterprises.
Check the hub portion of your rotors as later models have additional holes for two additional fasteners. The part # is C2N3427.
Note these, like many aftermarket rotors, are not zinc treated meaning the hubs of the rotors will rust. I painted mine with a zinc based primer and it has done the job nicely.
I've gotten brake parts from PartsGeek and found their prices to be reasonable.
06 2006 Jaguar XKR Brake Rotor - Brake - Brembo, Brembo Coated, Centric, EBC, Eurospare, Genuine, Pilenga, Winhere, Zimmermann, Front, Rear - PartsGeek
Like Marc suggested, some paint on the hub area is a good idea before installing to keep a cleaner look.
JPEC shows the caliper bolts as different part numbers for the R package vs non. I thought the calipers were the same, but maybe the R bolts are painted or some such.
Mendo XK (02-17-2013)
I have the Jaguar Electronic Parts Catalog installed. Almost as handy as JTIS.
https://www.jaguarforums.com/forum/s...ed-xmas-48052/
Dimitrigregorio
17
09-05-2019 03:47 AM
