Where to find splice between pillar tweeter and dash midrange - going 4-way active!
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I'm going 4-way active ![Icon Naughty](https://www.jaguarforums.com/forum/images/smilies/icon_naughty.gif)
And to do that I need to run separate leads to the tweeter and the midrange on the premium system, as they by default are connected in parallel like so:
![](http://img818.imageshack.us/img818/8465/tweetrg.png)
The easiest way to do this seems to be finding the splice between them, and then cut the wires going to the dash and hook them up to a new set of wires going to the trunk.
Does anyone know where to look?
Wow, active means separate amps for tweeters, mids, and lows as the signals are filtered before it enters the amplifiers? so one amp per speaker. In an active scennario there is no way you can use the existing wiring as all the wires have to come straight from the amplifiers to the speakers.
or do you mean one amp ->frequency filter -> on a 4 way component speaker set?
In my case I disassembled the frequence filter, and put the components directly on the respective speakers as I didn't have space to accommodate the filters either in the doors or in the central armrest and I didn't fancy running new cables.
Anyway, from the central arm rest the split is done to each speaker and depending on the year of your car and standard or premium sound system the pre laid cables might be change.
jagent
09-12-2015 01:40 AM
