Where is the fuel filter in a 2003 XKR?
The title says it all. Where's the fuel filter?
I tried looking under the car near the rear left wheel. All I saw was the fuel lines coming down from the tank area and continuing to the engine. JTIS said it's under the rear left seat pan. I lifted up the rear seat cushioning but could not find the filter or any access holes there. Is it accessible via the boot perhaps?
Thanks,
K
Thanks,
K
The following 2 users liked this post by GGG:
JagTheRipper (06-29-2017),
Salo (06-29-2017)
Graham,
Just finished replacing the two fuel pumps in the jag that had filters on the bottom. If that is where your problem is, there is a great video on how to. As you need to remove the fuel tank for proper access to the pumps IMHO. I am also going to post some more tips regarding what I did. There might be filters elsewhere but my problems were with the pumps.
Ken in WV
Ken in WV
While hunting for the cause for this code I've been doing quite a few preventative maintenance things that could lead to the code. One of them being using a fuel system cleaner (in case of clogged up fuel injectors) and a new fuel filter.
