Where is the throttle body connector please?
Old 07-24-2015, 02:50 AM
dibbit's Avatar
Are you going to try one of those replacement tps from eBay? I would try measuring the resistance at zero throttle before removing the old one and then use that figure to help get the new one in the right position when you install it.
Old 07-24-2015, 02:55 AM
worrasf's Avatar
Yes, I'm going to go for one of the new aftermarket ones. Strikes me that a used OEM TPS is just as likely to fail.
EDIT: just bought one: http://www.ebay.co.uk/itm/2718594973...%3AMEBIDX%3AIT
Got it for £90 + p&p from HK. No import or customs fees to UK unlike from US
Old 07-24-2015, 03:57 AM
dibbit's Avatar
Yes, a second hand one might even already be on its way out.
Let us know how you get on.
Old 07-24-2015, 05:58 AM
worrasf's Avatar
Default The plot thickens
Just had an opportunity to get a really good look at TPS and connectors.
I actually have the later gold pin connectors on the TPS loom which is good. But noticed that there was a small crack in the antibackout plastic next to connector 3 which might have been allowing the pin to make a poor contact intermittently. It looked like previous owner had tightened up the female connectors and split it. Simple repair with a little plastic repair epoxy - cleaned the connectors with Deoxit and did a hard reset. Now running like a charm. Feels like it's in sport mode when it isn't. Anyway, only time will tell but I'm ordering an new TPS anyway just in case.
BTW - where about in Spain are you? We have a house in Benaojan (just outside Ronda in Andalusia) - off there on Sunday. I'd love to take the Jag over for a run on the coastal highway (mind you I think I'd want a left hand drive).
Steve
Old 07-25-2015, 04:00 AM
dibbit's Avatar
That will be a nice fix if that is all it is. Even having to spend £90 on a new tps is a lot better than a new throttle body from Jaguar and just shows these cars can be maintained cheaply if you avoid the main dealers.
We are further up the coast from the Ronda end, close to the border with Granada province. The coastal road here is spectacular, well worth driving along, even in a RHD car.
Old 08-01-2015, 12:11 PM
worrasf's Avatar
So I ended up buying 2 brand new TPS - I will only need one so if anyone wants to take the other off my hands pm me
Gus
10-15-2019 12:29 PM
xjrjag
09-27-2015 01:53 AM
Lannyl81
09-19-2015 08:07 PM
mrplow58
09-09-2015 11:27 AM
Quick Reply: Where is the throttle body connector please?
